Buying a new router for my Plusnet Fibre
gooner77
I have borrowed an ASUS RT-N66Ufrom a friend with aview to buying it.
We had a PlusnetHubOne and had no end of issues with it. I have reverted to my previous Netgear router supplied by Plusnet and everything is fine. I would like a newer router with a bit more oomph and dual band which is why I bought the Asus
However I have had issues setting it up for internet. Its not accepting my plusnet account details and I'm not sure which connection type I should be selecting is it PPOE ?
Any advice would be much appreciated
rongtw
Fixes: 12
Re: Buying a new router for my Plusnet Fibre
this may help https://community.plus.net/t5/Fibre-Broadband/Asus-RT-N66U-connection-problems/m-p/1399609/highlight...
Fixes: 5
PlusNet have always been happy for customers to use 3rd party hardware. They have a web page giving the details required to connect.
https://www.plus.net/help/broadband/broadband-connection-settings/
SpendLessTime
Aspiring Hero
Fixes: 54
@gooner77
The RT in the model name means that the device is a router, it does not have a modem built in. The Plusnet Hub One does have a modem built in.
So you either get the DSL-N66U (the DSL means it has a modem built in) or buy a VDSL2 modem to use with the RT-N66U or still use the Hub One but connect the Asus as a WiFi access point to it.
gooner77
Forgot to mention I already have a modem. Thanks for the advice everyone
SpendLessTime
Aspiring Hero
Fixes: 54
