Building works down the road
- Building works down the road
05-12-2017 9:41 AM
Hi
I am wondering if there was a way to check broadband wiring to the box connector down the road as they been digging up the road between me and the box.
I hope you understand lol can you ask plusnet to find out if this can be possible to happen.
I am trying to be helpful and sympathetic to you. otherwise I may have to write to Andy Baker "Top Dog"
Martin
I love hobnobs you can nibble and then take a chunk out of it
Part of life living
Part of life living
Message 1 of 2
(314 Views)
1 REPLY 1
Re: Building works down the road
05-12-2017 7:22 PM
Unfortunately he will completely ignore you, so I shouldn't bother and I don't think PlusNet can check your wiring either apart from their usual line checks
Message 2 of 2
(283 Views)
