Buffering
- Buffering
Re: Buffering
04-04-2015 2:40 PM
I can't see any similar issue for your connection I'm afraid so it is a bit of a mystery as to why your connection is buffering.
The only thing I can suggest trying is a direct connection to the Openreach modem to rule out the Netgear as being at fault.
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Let us know if you have any further questions.
Re: Buffering
04-04-2015 4:02 PM
Re: Buffering
04-04-2015 4:37 PM
In your P2P client have you set a maximum upload speed. I'd suggest an absolute maximum of half of your upload sync speed.
Quote from: ricke17 I have tweaked the P2P client so the upstream runs slower. But some clarity would be useful for me (and others who are following this thread). When my upstream hits 2MB/s does this mean I am using almost all of the 20 out of my 80/20? And would it be the same when the downstream hits 8MB/s in respect of the 80 out of the 80/20?
Your post suggests you might be mixing up bits and bytes.
2MBs (bytes per second) = 16Mbps (bits per second) which will indeed mean you are using almost all your upstream.
Re: Buffering
04-04-2015 4:50 PM
Re: Buffering
04-04-2015 4:56 PM
Re: Buffering
04-04-2015 4:58 PM
Sorry it's all confusing.
Re: Buffering
04-04-2015 5:20 PM
Re: Buffering
04-04-2015 5:22 PM
Rick.
Re: Buffering
04-04-2015 7:28 PM
Re: Buffering
04-04-2015 7:29 PM
Re: Buffering
05-04-2015 8:01 PM
A friend asked Multiplay Via a TICKET what the problem was , their answer was the server wasnt the problem it was the ISP routing ?? causing me to have packet loss , even though i hopped gateway am now on PTW-AG03 it still the same
Re: Buffering
05-04-2015 10:06 PM
Re: Buffering
06-04-2015 7:00 AM
just been running to BBC 5mins and it says 65% packet loss
am on gateway ptw-ag03.
Re: Buffering
06-04-2015 9:39 AM
Re: Buffering
06-04-2015 11:19 AM
