Buffering on catch up
- Buffering on catch up
26-03-2021 8:54 AM
Hi all,
I just moved to Plusnet from BT. Called tech and my connection is consistent but iPlayer/4od/itv player are constantly buffeting, I can't watch anything. Netflix is absolutely fine, using all the apps on firestick.
I have tried splitting the WiFi into 2.4 and 5, and tried the firestick connected to both channels and this hasn't helped.
Could anyone help please?
Thanks so much!
Thanks so much!
Message 1 of 4
(318 Views)
3 REPLIES 3
Re: Buffering on catch up
26-03-2021 12:33 PM
If you still have your BT hub then use that. See here for settings https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
Message 2 of 4
(300 Views)
26-03-2021 1:14 PM
Ahhh I've just sent it back! Will see if I can find another thank you
Message 3 of 4
(295 Views)
28-03-2021 4:14 PM
Managed to find one and that seems to have solved the problem, thank you
