Budget Wireless Router
- Budget Wireless Router
- « Previous
- 1
- 2
- Next »
Re: Budget Wireless Router
04-11-2014 9:22 PM
Quote You don't unless you want to use just a single box and be eco-freindly tijara33
11110_110, how on earth will I be saving the planet by doing away with the OR modem?
05-11-2014 11:06 AM
My vote is the Talk Talk super router (HG635).
For around £30 from ebay, it has:
a very strong wireless both 2.4GHz and 5GHz
wireless ac, with a suitable wireless card in the PC it give a wifi connection >800Mbps
4 Gigabit ethernet ports.
can replace the BT fibre modem or connect to the BT modem.
Can be configure for plusnet.
05-11-2014 11:09 AM
I got my HH5 for £20 (along with a HH4 & a BT Vision box that will both end up on ebay when I get the pics done.)
05-11-2014 11:38 AM
It's only the HG635 which has a fibre modem and 5GHz wifi.
As a further check that it's a hg635, if there's a photo, the front right bottom corner has the talk talk logo.
Mine was £30 but that was some months ago, they may have become more popular now.
05-11-2014 12:14 PM
I have a free ap worth about £50 that any many people use because its good that you can have if you want.
dick:red All caps edited as per forum rule.
05-11-2014 1:14 PM
But does it have a good wireless, that was the OP's main requirement.
05-11-2014 1:39 PM
Yes the wireless on it is crackin, it's got 3 antennas. its only N but that should be enough? Ive used it on virgin as a pure AP and it's always given me full speed so 160mbps over wireless.
It was a monitoring unit but i flashed it with WW-DRT
Edit: Here's a better picture. I forgot it was sat behind me so I took one of the actual unit. Sorry it's sideways when you click it it is not.
05-12-2014 6:03 PM
TP-Link TL-WDR3600 N600 Wireless Dual Band Gigabit Cable Router(2.4GHz 300Mbps, 5GHz 300Mbps, 2 USB Ports for Storage Sharing, Printer Sharing, FTP Server and Media Server) https://www.amazon.co.uk/dp/B008QBAXI4/ref=cm_sw_r_awd_WjFGub092GKBS
Due to arrive tomorrow
06-12-2014 11:26 PM
Quote from: willas00 Ordered this one from Amazon
Hi, how was this router? any good?
07-12-2014 12:43 PM
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
08-12-2014 9:51 AM
Finally the TP-Link TD-W9980 came back into stock in the UK & I have it up & running. It ticks ALL the boxes.
4 gig LAN Ports
Combined VDSL/Router, no need for the Openreach modem
Great 2.4ghz range
Guest Wireless Network
2 USB ports for print server/file sharing
Load more features that I don’t understand
Looks the part
£70 inc delivery
Sorted.
08-12-2014 3:43 PM
08-12-2014 3:55 PM
I was lucky Broadband Buyer agreed to take it back for a swop to the TP-Link.
The Asus had some nice features like the Asus Aicloud which was very useful, my TP-Link does not have these features.
Decided to go with a static I.P. and use openvpn on my qnap nas to remote access my files instead.
- « Previous
- 1
- 2
- Next »
