Broadband won't login
Dickytwo
Hi, as of midday today our internet went down. Looking at the router, the DSL is synced but the login won't work. Nothing changed to the login. Plusnet issue?
5 REPLIES 5
Fixes: 94
Re: Broadband won't login
Try doing a factory reset by pushing a paperclip or similar in the router factory reset hole. Keep the switched closed for 30 seconds then leave it alone for a bit to see if it sorts itself out.
Dickytwo
Baldrick1, I had left this as a last resort as I didn't think it would solve it. But hats off, it has. All credit to you! God knows what happened.
My problem now is, I can't log in to the router. Either on the password I had previously set or the one on the back of the router.
Anyone else had this or have those nasty PlusNet people done something remotely?
Fixes: 94
You are using the correct password, that's the admin one, not the wifi one?
Dickytwo
Login worked after another reboot. Thanks for helping, much appreciated!
Fixes: 104
Glad to see that's been sorted. Do should up if you have any other problems.
 Adam Walker
