Broadband won't connect anymore
meganbrewis29
I have a hub one router and upgraded to fibre a couple of months ago. Have had no problems until a few nights ago the broadband kept going off and failing to connect prompting an orange flashing light and the red broadband light. By the time I woke up in the morning the light was back to blue and I could get on the Internet no problem. The problem happened again lastnight and the light is still orange, have tried restarting the router and using the master socket but nothing has worked!
Butlinsbabe
Re: Broadband won't connect anymore
mines been down since yesterday morning.... I'm in Worksop... whereabouts are you? Wondering if its a local thing?
meganbrewis29
I'm in Leeds
Fixes: 167
Sorry that you're having problems with your connection I'd advise getting this reported to us as a fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
Fixes: 36
Does your phone work?
Laburnum
I am having the exact same problem on a hub one in swaffham, Norfolk. The WAN internet connection keeps freezing/dropping. The hub is also occasionally flashing yellow and red. The symptoms have appeared in the last few days. The only way to restore WAN connectivity is to restart the router from the LAN user interface. I have logged a fault.
Fixes: 542
Your connection has been fairly intermittent over the past week.
My tests aren't identifying the cause of that. Have you tried plugging the router into the test socket?
