Broadband speed
Squib
Broadband speed
In the past two weeks I have had 2 visits by OPENREACH engineers, the first was for a noisy line , he found a loose crimp in a cabinet , so I am thinking this is good (speed goes up to 14 meg) however the speed drops back to 6.7. Second engineer arrives as I have reported slow broadband speeds in consultation with a Plusnet employee, he finds nothing as usual , but says he can't understand the low speeds , he resets some equipment to start giving us 30 meg , but speed goes down to 6.7 within minutes. I should be able to get higher speeds than that , in fact I have received 14 meg shortly after first engineer visit. OPENREACH engineer told me that Plusnet has a certain amount of control over the speeds to customers, why do they have to get involved in adjusting speeds ?
5 REPLIES 5
MatthewWheeler
Fixes: 479
Re: Broadband speed
Sorry to hear you've had issues,
Can you try rebooting your router?
There was a stuck profile however this is now gone so you should be getting better speeds.
 Matthew Wheeler
Squib
Re: Broadband speed
Rebooting seems to have worked for the moment, speed now up to 14.5meg.
Squib
Re: Broadband speed
December 4th phone line still noisy , broadband speed back down to 6 meg , I am getting really fed up.
PeeGee
Re: Broadband speed
Until you get your line sorted so that the noise is no longer present, you cannot expect the best speeds to be maintained.
You will have to repeat the "phone fault" procedure to do that.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
MatthewWheeler
Fixes: 479
Re: Broadband speed
As you've been advised if the phone line is still noisy we'll need to get that fixed first/
 Matthew Wheeler
