Broadband speed ridiculously slow
- Broadband speed ridiculously slow
09-08-2016 2:37 AM - edited 09-08-2016 2:42 AM
Attached photo of current speed.
Re: Broadband speed ridiculously slow
09-08-2016 9:00 AM
Welcome to the forums.
First place to start is with the information from https://community.plus.net/t5/Fibre-Broadband/Fibre-Speed-Faults/m-p/1270253#U1270253 so that people can offer help and advice with a clearer picture
09-08-2016 9:53 AM
Sorry that you're having problems with your connection.
Sync Status | In Sync |
Downstream Speed | 14.4 Mbps |
Upstream Speed | 4.8 Mbps |
Appointment Required | N |
Fault Report Advised | Y |
NTE Power Status | PowerOn |
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue |
Test Result: Fail - Fault located in local network
Description: FAULT - Battery Contact
This fault has been reported through to Openreach as it's important to ensure there are no phone line issues as these can cause problems with broadband connections.
09-08-2016 9:57 AM
09-08-2016 10:06 AM
A fault has been detected along the line external to your premises, this has been reported through to Openreach and once they get back to us we'll be back in touch.
