Broadband speed ridiculously slow
Betty477
My fibre broadband extra speeds are currently at 10 down and 0.25 up. I pay good money for them to be in high 40's minimum down. Not impressed at all, what can be done?
Attached photo of current speed.
SpendLessTime
Aspiring Hero
Fixes: 67
Re: Broadband speed ridiculously slow
@Betty477
Welcome to the forums.
First place to start is with the information from https://community.plus.net/t5/Fibre-Broadband/Fibre-Speed-Faults/m-p/1270253#U1270253 so that people can offer help and advice with a clearer picture
Fixes: 162
Sorry that you're having problems with your connection.
Sync Status In Sync
Downstream Speed 14.4 Mbps
Upstream Speed 4.8 Mbps
Appointment Required N
Fault Report Advised Y
NTE Power Status PowerOn
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Test Result: Fail - Fault located in local network
Description: FAULT - Battery Contact
This fault has been reported through to Openreach as it's important to ensure there are no phone line issues as these can cause problems with broadband connections.
 Chris Parr
 Plusnet Staff
Betty477
Hi, thanks for response, could you explain these fault readings for me please?
Fixes: 162
A fault has been detected along the line external to your premises, this has been reported through to Openreach and once they get back to us we'll be back in touch.
 Chris Parr
 Plusnet Staff
