Broadband speed low since around week 2 of joining
- Broadband speed low since around week 2 of joining
13-01-2017 10:20 PM - edited 13-01-2017 10:21 PM
Re: Broadband speed low since around week 2 of joining
14-01-2017 11:57 AM
Hello @Daniellelarge15
I'm sorry to hear you're having issues with your broadband. I'm testing your line and I'm not finding an issue with the speed.
Sync Status | In Sync |
Downstream Speed | 80.0 Mbps |
Upstream Speed | 20.0 Mbps |
The connection from your exchange to your router is also pretty stable:
The issue appears to be indeed related to your wireless connectivity. Can you try running through the checks here: https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
14-01-2017 1:59 PM
14-01-2017 2:01 PM
Thanks for getting back to us,
Hmm. Would you be able to test your speed at http://speedtest.btwholesale.com completing the further diagnostics and if it's still slow, raise a fault to us at http://faults.plus.net to get this looked into by our faults team.
14-01-2017 2:05 PM
14-01-2017 2:10 PM
14-01-2017 2:15 PM
We'll need to investigate this, but as we're seeing a sync speed of 80 Mbps you'll need to complete the BT wholesale further diagnostics and raise a fault to us.
14-01-2017 2:19 PM
14-01-2017 2:21 PM
Thanks. Once you complete the further diagnostics, this result will be logged on to the BT wholesale servers. Then I'd advise raising a fault to us at http://faults.plus.net and our faults team will investigate.
14-01-2017 4:15 PM
Are you using the Now TV box to test with?
If so, are the test results you've posted also taken from the box itself?
Or are these results from either a PC/Laptop connected via Ethernet to your Router?
(only reason for posting is that from previous experience, although the 'puk' is/was a great way to stream content to the TV (I had one too), I wouldn't rely on it's speed test results)
