Broadband slow and unstable, multiple drop outs
Aitch21
For about the last 5 weeks broadband has been slow and unstable. Multiple devices report slow and unstable connection at various times (for example TV spends a lot of time buffering then reports that the connection has dropped). Drop outs are frequent. Re-starting the router tends to stabilise things but problems return after 12-24hours. Sometimes the router takes some persuading to come back on line.
I've tried following the troubleshooting but haven't found the problem, although I couldn't source an alternative router and this seems the most likely cause. My wall socket is the type with the telephone and broadband  sockets one above the other and no separate modem.
I appreciate it's difficult to diagnose but the whole family are getting frustrated and blaming me!
Tags (2)
38 REPLIES 38
Legend
Fixes: 255
Re: Broadband slow and unstable, multiple drop outs
@Aitch21 Welcome to the forums. Two suggestions - (1) dial 17070 from your landline, select option 2. After confirming your phone number, the only thing you should hear is the 'Quiet Line Test' message - any other noise at all, report a phone fault first.
(2) Post the results from your router Help Desk page - it may give us an idea.
Aitch21
Thanks John, quiet line test seems quiet.
Sorry for being dumb - how do I find my router Help Desk page?
Legend
Fixes: 255
Does this picture help?:
adam945
Fixes: 113
Hello @Aitch21
Thanks a lot for reaching out and I'm really sorry to hear that you've been having problems with your broadband service. To be honest, tests on the line aren't picking these disconnections up, I'll pop a visual radius below. Can I ask, when did you split the SSID's on your router? This is usually a common fix as we did have some well documented problems with the 5GHz band recently.
Going forward, please have a look through our support article on improving your wireless connection, and let us know if the problems continue.
WIFI Support https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
-Adam - Leeds
 Adam
 Plusnet Help Team - Leeds
Aitch21
Thanks John, I've got this
Aitch21
I split the SSIDs over a year ago after reading advice on this forum that this could cause drop outs. All been fine, with 4 of us at home doing lessons and work, until a few weeks ago.
Legend
Fixes: 255
@Aitch21 Thanks for that screenshot, I note the connection has only been up for a short while - have you had multiple total drop-outs? Your Attenuation looks as though you are mightily close to the cabs?
Legend
Fixes: 255
@adam945 Any chance of that Radius log? 😉
Aitch21
Keep having to re-set the router as that is the only way we can get a stable connection for a few hours , but that is getting less and less.  Drop outs happen very frequently on several devices.
Legend
Fixes: 255
OK, @Aitch21 Continuous multiple resets could upset the Dynamic Line Management, although apart from the SNR values looking a bit - which could be due to your closeness to the cabs, and therefore not a worry, I too can't see any reason for your issues.
Another thought - are you on a 40/10 or 80/20 profile, do you know?
Aitch21
Thanks @jab1 . Sorry, what do you mean "closeness to the cabs"? Does this mean that the router is too close to the electrical wire?
Sorry, no idea about the profile.
I've changed the channel to 11, from 6.
Aitch21
Seems to be disconnecting repeatedly while I'm chatting to you here - "a network change is detected"
Legend
Fixes: 255
No, 'closeness to the cabs' means that I suspect the BT 'green boxes' must be almost outside your house to give the figures on the Help Desk, which is good.
Easier question re: the profile - are you on 'Plusnet Fibre' or 'Plunset Fibre Extra'?
Leave the channels alone for a while - I don't think they are the issue.
Legend
Fixes: 255
Sorry - without sight of the logs that show that, I wouldn't like to comment - I'm not a network expert.
