Broadband service activation
- Broadband service activation
14-07-2021 10:10 AM
Received my router last week my switch on date wasn't until the 13th which was yesterday haven't had broadband in the house for nearly 3 weeks so you can imagine having a teenager not being able to play on his console anyway.. my switch on date was yesterday plugged my router in waited the time it was telling me as I received an email to say everything was good to go and if the light went blue it was connected. Plugged my router in waited for it to go blue, it went blue for a couple mins then straight to orange with a flashing red b sign. Waited until midnight just incase checked this morning and it's still the same. Iv waited long enough without broadband so to have this now is a joke especially moving from sky where the broadband was good just the billing was to high. Can someone tell me when my broadband router will actually connect
Re: Broadband service activation
14-07-2021 1:14 PM
HI @Redbeard90, thanks for getting n touch and welcome to our Community Forums.
I'm sorry to hear you had issues with the service activating yesterday but I can confirm when checking your connection since posting earlier today it looks like your connection is now live. Is everything now up and running your side fine?
18-07-2021 8:06 PM
18-07-2021 9:04 PM
Thread moved from Fibre Broadband to My Order.
Forum Moderator and Customer
19-07-2021 9:18 AM
Thanks for getting back to us @Redbeard90
I'm really sorry to see you can't get online. I can see while you raised a fault ticket to us Here this morning you noted there's no dial tone on your home phone line. Can you confirm if this is still the case?
Also have you tried plugging the router into what's known as the test socket explained Here? That'll rule out any internal wiring from causing an issue. Let us know how it goes as we may need to arrange an engineer visit with you.
22-07-2021 4:50 PM
22-07-2021 5:19 PM
Hi @Redbeard90, thanks for getting back to us and I'm sorry to hear the connection issues you're having look to be persisting. I've looked into and help progress the fault on your account that requires your attention and can be seen here:
https://www.plus.net/wizard/?p=view_question&id=216285376
If you could please read through the fault update on your account and should non of the advised steps look to help with the dropping connection then please do get back to us with the required information so we can look to progress this issue further for you. (You may need to be logged into the member center prior to clicking the link above in order to add a comment.)
We look forwards to hearing from you further.
