Broadband problems
- Re: Broadband problems
Broadband problems
11-12-2016 5:44 PM - edited 11-12-2016 5:46 PM
hi, have been getting intermittent problems all weekend with high latency (averaging 600 ms, usually 10) and packet loss (around 15%). Been using the service since August and aside from planned maintenance, has been fine.
Would appreciate some investigation to see if theres a fault. Checked the router, resynced / reconnected to plusnet network, issue is the same with ethernet or wireless.
Here are the various tests ive conducted:
12-12-2016 12:38 PM
I've just been running diagniostics which aren't showing any obvious causes for this and the connection looks fine from our point of view.
It would be wise to report a fault with us (http://faults.plus.net) but I'd just make sure you've ruled out what you can here first: https://www.plus.net/help/broadband/connection-troubleshooting/
12-12-2016 4:48 PM
is this after or during you've attempted to upload something or a device is backing up? Seems a few of us are having this issue.
13-12-2016 10:43 PM
I dont have any incremental back up services connected to my home line and no other uploading occuring. Line was ok again through to this evening, now I have been getting intermittent lag spikes again.
13-12-2016 10:44 PM
Router has been giving these statistics:
Upstream | Downstream | |
Current Rate(kbps) | 10619 | 53211 |
Max Rate(kbps) | 10619 | 52819 |
SNR Margin(dB) | 6.2 | 6.3 |
Line Attenuation(dB) | 0 | 21.6 |
Errors(pkts) | 272 | 204 |
16-12-2016 11:16 AM
I raised a fault as suggested on Sunday (#140014761), im still yet to be told what the problem is and when it will be resolved. The problem has got worse, I have average latency of 800ms, since last night, continuing through to now, so its no longer intermittent. I want an action or answer today, or else I'll be moving my line, 5 days without even confirmation of what is happening is completely unacceptable. I work from home and this is making connecting to remote services pretty much impossible at the moment.
19-12-2016 2:09 PM
