Broadband keeps dropping out multiple times a day
- Broadband keeps dropping out multiple times a day
Re: Broadband keeps dropping out multiple times a day
11-08-2018 12:05 AM
Connection definitely isn't stable. Has dropped out at least once since I've been away this week on holiday. Can someone check that graph thing that was shown at the start of this thread and see how many times in the last week please?
11-08-2018 1:05 AM
1:04am - just dropped again.
11-08-2018 11:05 AM
Dropped again, 11:02am
11-08-2018 1:33 PM - edited 11-08-2018 1:34 PM
Hi @Phalanx,
I'm sorry that your connection is still dropping. Your connection log is showing that there have been six drops over the last week:
However, testing your line is no longer picking up the external fault:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 79.9 Mbps | ||||
Upstream Speed | 12.6 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 659.0 | ||||
Upstream Rate Assessment | Reasonable | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed on Sundays | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | No Timing Information | ||||
Interference Location | Unknown | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-07-29T13:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 77.2 Mbps | 79.9 Mbps | 79.4 Mbps |
Up Stream Line Rate | 11.7 Mbps | 12.7 Mbps | 12.2 Mbps |
Up Time | 450.0 Sec | 900.0 Sec | 899.0 Sec |
Retrains | 0.0 | 7.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-11T12:04:32Z | 2018-08-11T12:19:32Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please can you run through our troubleshooting guides here and let us know how you get on. Please let us know if this problem persists once you've done the troubleshooting checks - if so, we'll investigate this further for you.
11-08-2018 1:50 PM
I have run through those items before, and don't really want to repeat everything again as I have to remove the front plate once more and stuff. It didn't work last time.
11-08-2018 4:08 PM
12-08-2018 3:07 AM
Just had another drop:
03:05:17, 12 Aug. | (47981.770000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
03:05:15, 12 Aug. | (47980.190000) PTM over DSL is down after 798 minutes uptime |
03:05:15, 12 Aug. | (47980.180000) PPPoE is down after 797 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
03:05:12, 12 Aug. |
(47977.570000) PPP LCP Send Termination Request [User request] |
I'll be doing the master socket test tomorrow, as I'm waiting on a filter to arrive.
12-08-2018 3:43 PM
OK, filter installed and it is connected directly to the test socket in the master port.
12-08-2018 3:46 PM
Not sure if this will help in your case.
I had repeated disconnects when I first got the PN broadband. Changing the microfilter stopped the disconnects. So I guess the microfilter I had was somehow not working properly.
Good luck.
12-08-2018 3:52 PM
Well, we shall see. My faceplate is one of those integrated ones, so no need for a microfilter. We'll see if this helps. If it does, I guess it's the faceplate on the master socket.
13-08-2018 10:06 AM
15-08-2018 8:35 PM
As of this post, the connection had been reset 18 hours ago. It was better, yes, but the problem still persists.
15-08-2018 10:42 PM
10:40pm dropped again.
16-08-2018 11:48 AM
16-08-2018 11:54 AM
Please see message 23 on the thread. I did that: https://community.plus.net/t5/Fibre-Broadband/Broadband-keeps-dropping-out-multiple-times-a-day/m-p/...
