Broadband keeps dropping out in Ipswich area
- Broadband keeps dropping out in Ipswich area
26-09-2018 5:59 PM
Hi
I've noticed during the last couple of days that the router keeps dropping connections. The light turns orange, flashes for a bit and then turns blue again. Are there any issues in the Ipswich area?
Message 1 of 2
(311 Views)
1 REPLY 1
Re: Broadband keeps dropping out in Ipswich area
27-09-2018 11:40 AM
Hi @paulrmoss,
I'm sorry that your connection is dropping and for any inconvenience that this is causing you. I can see that you've now discussed this with our technical support team and a potential external issue has been found. This has been raised to our suppliers for further investigation and we're due an update by 29/09. Our faults team will be in touch once we have the update.
Message 2 of 2
(280 Views)
