Broadband drops most days at similar time
- Re: Broadband drops most days at similar time
31-07-2020 10:11 AM - edited 31-07-2020 10:25 AM
Hi All,
I've seen similar posts about this fault.
My fibre broadband seems to drop out (not every day) around the same time. This appears to be roughly 9:50pm - 10pm.
I'm using the Plusnet Hub One router.
Having a look in the system logs on the router don't seem to show much but then I noticed in Advanced settings > Broadband > Connection Information that it does indeed show the connection went down 12 hours 11 mins ago (posting at this at 10:11am so links in with the ~10pm drop out). See below.
The connection does recover on it's own after about 5-10 mins.
Any ideas what this is?
Internet Connection Configuration
31-07-2020 12:10 PM
Im getting this 2/3 times a day and just generally slow speeds. Complained to keep getting told nothing is wrong even though I send them speed tests showing its happening.
Hopefully they can find a solution to this
03-08-2020 12:15 PM
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
