Broadband dropping in and out
- Broadband dropping in and out
16-03-2020 9:36 AM
Re: Broadband dropping in and out
16-03-2020 11:57 AM
16-03-2020 1:21 PM
Your choices are to try to help yourself by providing more information so that you get further advice or sign up with another ISP and in a few weeks be transferred to another ISP. The downside of this approach is that the fault might follow you and of course receive a large bill for cancelling your contract.
The first things to identify is whether you have a network or wireless problem. When connection is lost are there any changes to the indicator lights on your router?
16-03-2020 1:49 PM
16-03-2020 3:06 PM
16-03-2020 3:07 PM
You can only cancel without penalty if you give Plusnet sufficient opportunity to get the problem fixed. It sounds like you have a network problem so you need to report the fault to Plusnet, your line is not automatically monitored so unless you report it no one knows that there's an issue that needs addressing.
You can either ring in or wait until a Plusnet staffer comes along here and picks it up for you.
16-03-2020 9:15 PM
21-03-2020 9:36 AM
Thanks for getting in touch @Tim1100i and apologies for the delayed response.
I'm sorry to hear that you're having issues with your connection.
I've tested your line this morning and found a potential fault on the line that will most likely need a engineer to visit the property to resolve.
Unfortunately our suppliers systems are down for maintenance until 5pm so we can't progress this until then but I'll get one of my colleagues to pick this up for you and update you with the next steps.
If you can respond to this thread once my colleague has updated you we'll get that picked up
21-03-2020 12:18 PM
21-03-2020 6:14 PM
