Broadband dropouts
mcjizja
Broadband dropouts
I recently moved from another provider, and with them had a reliable broadband connection. Since being with plusnet I have had lots of drop outs. It usually comes back online fairly quickly but nevertheless annoying. I'm hoping this is teething problems and can be resolved. Can you do a line check please to see if there is anything obvious?
Fixes: 167
Re: Broadband dropouts
Unfortunately it appears that you may be affected by the same issue as some other customers are seeing where uploading is causing your connection to drop. Next time you start to see disconnections can you try stopping anything that's uploading and see if the disconnections stop.
 Chris Parr
 Plusnet Staff
mcjizja
In a house full of smartphones and laptops doing cloud backups etc thats kind of hard to achieve! But I'll try and see if there are any patterns.
Is it occurring for uploads over a certain threshold etc? Is there a resolution being worked on?
Fixes: 212
It's certainly being looked in to.
I believe more on this has been discussed over here: https://community.plus.net/t5/Fibre-Broadband/Plusnet-fibre-broadband-does-not-cope-with-uploads-and...
 Harry Beesley
