Broadband down again :(
- Re: Broadband down again :(
16-10-2018 8:38 PM
16-10-2018 9:04 PM
17-10-2018 1:16 PM
Hi @woodyncfc85
Thanks for getting in touch. Glad to hear you're back online.
I can see that you're currently connected to the internet but have experienced drops in connection over the last seven days (and beyond). I've tested your line and no external faults are present. With this in mind it’s likely that the cause of the drops is within your premises.
Could you run through our troubleshooting guides here primarily and see if this helps?
If this doesn't resolve the issue I'd suggest raising a fault here so that we can progress this for you:
Thanks,
Dave
07-11-2018 9:20 PM
07-11-2018 9:23 PM
07-11-2018 10:36 PM
07-11-2018 10:53 PM - edited 07-11-2018 10:55 PM
I suspect you are unlikely to get a response tonight @woodyncfc85.
Happy to be proved wrong though.
07-11-2018 10:59 PM
08-11-2018 4:56 PM
08-11-2018 5:39 PM
Have you reported a fault?
08-11-2018 5:46 PM
08-11-2018 7:31 PM
09-11-2018 1:54 PM
Apologies for the delayed response and that you're experiencing connection problems.
Our tests aren't finding a definitive cause of the problem, but please let us know how it goes when you receive your replacement router. It may also be worth trying the steps Here if you haven't already. This will rule out any internal wiring.
