Broadband activation
FIXED- Subscribe to RSS Feed
- Broadband activation
05-09-2018 6:18 PM
Fixed! Go to the fix.
Re: Broadband activation
05-09-2018 6:30 PM
Hi @LS
Welcome to the forums!
Looks like your orders all completed as we expected them too - but there was some delay in the final process of your circuit activating.
I've manually updated this for you from our end.
Could you reboot your router and try establishing a connection for me?
Thanks,
MoR
05-09-2018 6:36 PM
05-09-2018 6:43 PM
Our tests are showing that your router is in sync - therefore a signal is indeed reaching our premise.
Could you try a full reset via the little hole at the back for us? You'll need to hold something small in there for about 20 seconds.
Can you tell me what your device says when you try and establish a connection as well?
Thanks,
MoR
05-09-2018 6:55 PM
05-09-2018 7:03 PM
Could you take a look through our troubleshooting guides here ?
As I said everything looks spot on from our side.
I'm really sorry about this.
Thanks,
MoR
05-09-2018 7:09 PM
05-09-2018 7:15 PM
Can you log into the Hub Manager with the Admin Password?
You can find this on the same card your WiFi password is on - once you are in can you please check that the username and password are correct inside the "Basic" details section? If they are wrong please can you update these, they should be the same as your account username and password.
Thanks,
MoR
05-09-2018 7:25 PM
05-09-2018 7:32 PM
That right there will be your issue! That "setup" should be your account password.
Can you try this :
1) To connect to your Hub One, you will need to open a browser and go to http://192.168.1.254
If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Broadband.'
4) You will see some default options, if not, please press 'Disconnect' on the right and this will allow you to change the Username and Password.
5) For your username, this should be your account username and should be in the following format: username@plusdsl.net
Your password is your account password
6) Press 'Connect' and you should be online.
Let us know how you get on
MoR
05-09-2018 7:43 PM
05-09-2018 7:48 PM - edited 05-09-2018 7:49 PM
No worries at all! That's what we are here for.
I have a feeling my manual intervention to fully complete your order may have caused the TR069 protocol to not auto assign your credentials to your router. Which is why is showed the "setup" username. Sorry about that, it was required, however, due to the situation we were in before that point.
Anyway, glad to hear you are now up and running.
If you need any more assistance give one us a shout on here - we're always happy to help.
Have a great night!
MoR
*typo edit
