Broadband Username Ending @plus.net
FIXED- Subscribe to RSS Feed
- Broadband Username Ending @plus.net
29-12-2018 2:12 PM
My broadband username ends @plus.net rather than the normal @plusdsl.net, probably because I have been a Plusnet broadband customer since 2002. Is it possible, and if so is it advisable, to have my broadband username changed to the normal @plusdsl.net? The main drawback of my existing username appears to be that I have to set up new Plusnet routers manually rather than them connecting automatically.
Fixed! Go to the fix.
Re: Broadband Username Ending @plus.net
29-12-2018 3:18 PM
Hi Martin.
This is something we can arrange but you'll need to update the username in the router or you'll lose connection when it next drops
If you're happy for me to do this just post back
29-12-2018 3:38 PM
Matthew
Please update my username. I'll then update my router once you have made the change.
Martin
29-12-2018 3:56 PM
12-01-2019 10:06 AM
After the change of my broadband username so that it now ends @plusdsl.net my broadband has worked without any problems. However, my data usage has been shown as zero ever since the change was made. I was hoping that this would start working again after I had received my latest monthly bill but this hasn’t happened. Can this be corrected now?
12-01-2019 4:02 PM
Thanks for getting in touch and I am sorry that you aren't able to see your usage.
I have reviewed your account and have responded via a ticket here
If you have any further questions feel free to get in touch.
