Broadband Speed
- Re: Broadband Speed
Broadband Speed
01-12-2020 11:03 AM
Hi All,
Hoping someone could enlighten me on my current broadband speed. When I first got my connection, i was running in around 8mb download. Recenly my speed dropped considerably and a line fault was found. OR switched me to a new pair in the main line to the green box. However, my line hasnt returned to those previous speeds, instead lying between 6 - 6.5 ish. This is above the minimum speed, but not as good as it was before. Can anyone tell me if this is roughly right for my line, is it worth reporting anotehr fault?
Any advice appreciated, see some stats below...
Re: Broadband Speed
02-12-2020 8:55 AM
Never mind, no connection today so fault reported. Have dial tone but line seems a bit noisy. Engineer said he moved me onto the last good pair in the line, does that mean the line will need replaced?
Cheers,
Jonny
