Broadband Speed Very Poor
- Broadband Speed Very Poor
06-12-2020 6:37 PM
I've had a patchy weekend with Zoom Video breaking up so I thought I ought to test the speed. It's terrible.
I can usually exceed 20 Mbps (the Fibre Cabinet is 1km away)
Just got the attached report saying 461Ms Latency and only 1.84Mbps Download
Re: Broadband Speed Very Poor
07-12-2020 9:46 AM
As always the first question if you don't spell it out has to be is this yoir broadband speed measured using an Ethernet cable between your hub and computer or possibly a wireless problem?
07-12-2020 9:54 AM
Yes. A wired connection through the latest BT Smart Hub 2 Router.
Speed check later in the evening showed a return of speed so it really is intermittent. And now this morning after a slow start the speed is good.
I didn't mention that OpenReach were down the road last week pulling through Fibre for FTTP. Have they pulled on flaky joints?
07-12-2020 6:46 PM
Router has lost connection several times today. Sometimes it comes back up with adequate speed but now running slow again with high ping delay. See attached
08-12-2020 1:27 PM
Plusnet have called out OpenReach because the "GEA Test" shows...
Impairment in copper joint detected most likely close to customer premises. Please continue to submit a trouble report |
