Broadband Issue - is support available?
- Broadband Issue - is support available?
03-04-2020 10:25 AM
I am having issues with my broadband connection dropping in and out. I have been through the check list online. I have called the support numbers but they don't seem to be working and the online chat is offline. Anybody know how I can speak to someone at Plusnet?
Re: Broadband Issue - is support available?
03-04-2020 10:35 AM - edited 03-04-2020 10:36 AM
@Ptj21 Welcome to the forum.
The Chat service is permanently off line. The telephone service is working but being swamped by calls. If the queue gets unacceptably long you get referred here.
Plusnet staffers do come along and pick up posts but they are currently thin on the ground.
When you say that your broadband drops in an out can you give a bit more detail, for example, which hub are you using, are you connecting to it wirelessly or over an Ethernet cable and are the lights on the hub changing when your connection drops?
03-04-2020 3:27 PM
03-04-2020 4:40 PM
Try splitting the wireless bands as explained in this thread. https://community.plus.net/t5/My-Router/Hub-one-dropping-connection-too-frequently/m-p/1722387#M1742...
