Broadband 40Mbps to socket, 3 Mbps from hub: Why?
- Broadband 40Mbps to socket, 3 Mbps from hub: Why?
06-06-2020 11:01 PM
Hoping someone out there can help with this mystery.
I was getting downloads speeds around 30 Mbps until about a month ago when the speed suddenly dropped to between 2 and 4 Mbps (depending on the time of day).
The Plusnet One Hub tells me I'm getting 40Mbps down and 9.99 upload speeds, so I thought there might be a problem with the router. Plustnet sent me a new one which I connected up today - but the problem persists.
BTW speedcheck tells me I'm getting 3.82 this evening. The hub is connected to the master socket, and the computer is connected to the hub via ethernet cable. Wireless connection speeds to phones and iPads are similar.
Screenshots attached - Hub DSL status and BTW speedcheck stats.
Grateful for any advice on what might be going on here!
Re: Broadband 40Mbps to socket, 3 Mbps from hub: Why?
07-06-2020 8:18 AM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
07-06-2020 10:18 AM
Your screen shot is 2 copies of the DSL stats which, unfortunately, does not include noise margin, attenuation and errors that are more useful (see attached - but ignore Max Rate, it is "just for fun")
Phil
07-06-2020 3:19 PM
