Blue light but not working
gemuk83
I have a solid blue light on the router and when I log into it it says it's connected. My phone and computer are also both showing as connected but I can't get online on any device. Anyone know what's happening? Thanks.
notmyname
Re: Blue light but not working
If you log into the hub one, and click on "Settings", what does it show for the username?  If it shows "your-user-name"@plusdsl.net, the you should be fine.
If it shows setup@plusdsl.net, you will need to update the details to the correct ones.
Fixes: 538
Hi there.
I'm sorry to hear you're experiencing connection problems.
Our checks are showing an active connection. Are you using wired or wireless connections? If you're using WiFi, can you try a wired connection to narrow down where the issue lies?
Also, it might be worth doing a factory reset of your router by pushing a paperclip into the reset hole at the back for 20 seconds.
Let us know how you get on.
notmyname
Might be worth doing a session kill @Gandalf
Fixes: 538
I'm not sure that will help as it looks like they've tried switching the router off for over an hour:
gemuk83
Seems to be working again now without me doing anything! I'll see how it goes. Thanks for your replies.
Fixes: 538
Glad to hear you're back up and running.
Let us know if you need any further assistance.
