Billion BiPAC 8900AX R2 - Setup Guide
- Re: Billion BiPAC 8900AX R2 - Setup Guide
15-04-2016 8:02 PM - edited 15-04-2016 8:07 PM
Thought I might post this to help people with this router or those who are considering buying it.
Setup - Configuration > WAN:
802.1P: 0
802.1Q: 101
Username that was originally setup: ('''@plusdsl.net)
Authentication method: CHAP
Is it better than the Hub One:
Billion
Hub One
As you can see both sync at the same speed, but I can't see all the stats on the Hub One.
Wired speed test on the Billion
19-04-2016 9:14 AM
If it help anyone, the following link shows how to configure multicast TV (Youview box) on a Billion 8800AXL.
The set up looks very similar to the 8900AX.
http://www.increasebroadbandspeed.co.uk/2015/setting-up-billion-8800-bttv-multicast
22-04-2018 5:47 PM
Thanks! Have just bought a Billion 8800AXL R2 (a newer revision of the 8800AXL) and @npr instructions (in the link) worked perfectly for setting up multicast on the new modem/router (so Plusnet's channels now work on my YouView+ box).
Thanks again to both of you.
12-09-2018 11:55 AM
this helped me so much thank you thank you!!!
