Billion BiPAC 8800NL
- Billion BiPAC 8800NL
17-08-2015 6:51 PM
Re: Billion BiPAC 8800NL
17-08-2015 7:01 PM
See http://community.plus.net/forum/index.php/topic,138405.msg1219179.html#msg1219179
Others here have found it working OK straight out of the box so try that first!
York.
17-08-2015 7:08 PM
17-08-2015 7:15 PM
Quote from: NedLudd I did have a problem but soon got some help from this site!
I think Billion added settings for Plusnet too its latest firmware!
18-08-2015 3:01 PM
18-08-2015 3:14 PM
Does anyone know if you need to leave 30 minutes in between switching off the BTOR modem and switching on the Billion ?
Thx
18-08-2015 3:25 PM
18-08-2015 3:27 PM
18-08-2015 3:42 PM
19-08-2015 1:16 PM
After 3 weeks of very low upload speeds (~2Mbps) despite OR visit and tests showing line fault it has synched at 58547 down and 18999 up.
Thinkbroadband speed test http://www.thinkbroadband.com/speedtest/button/143998835411247525046.png
Best figures I have ever seen in nearly 3 years of FTTC. Keeping my fingers crossed that problem was OR Modem
19-08-2015 1:48 PM
19-08-2015 2:37 PM
York.
19-08-2015 4:05 PM
20-08-2015 10:27 AM
disconnected ppp then powered off the router waited a minute then the modem.
Left it for over an hour then connected the billion.
Downstream connection has jumped from 12Mbps to 17Mbps
Upstream no change
Is there anything that can be done at the plusnet end to help my upstream ?
Does anyone know of any tweaks on the billion for more speed ?
ps so my current line speed is now greater than the estimated
Phone exchange:
MEARE HEATH
Estimated line speed:
16Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-07-25 12:39:50
Current line speed:
17.4 Mb
