Billion BiPAC 8800NL
adagio
Just ordered a Billion BiPAC 8800NL - any issues with setting up for PlusNet?
Re: Billion BiPAC 8800NL
I did have a problem but soon got some help from this site!
See http://community.plus.net/forum/index.php/topic,138405.msg1219179.html#msg1219179
Others here have found it working OK straight out of the box so try that first!
Geoff,
York.
Fixes: 62
I used this which I think came from a post on here and I had no problems
mlmclaren
Quote from: NedLudd
I think Billion added settings for Plusnet too its latest firmware!
adagio
Thank you all for taking the trouble to reply. Hoping for delivery in the next hour or so Smiley
CBR600
Just ordered mine.
Does anyone know if you need to leave 30 minutes in between switching off the BTOR modem and switching on the Billion ?
Thx
Terranova667
Edit.. my bad just realised Swapping for a all in one so yeah I would do a 30 minute wait just in case.
mlmclaren
The 8800NL has built in modem so I;m assuming the OP was for changing the modem for the AiO!
CBR600
thanks  Cool
adagio
Arrived yesterday evening. Setup this morning trivially easy - only had to tell it PTM (VDSL) and enter username and password and connected  Smiley
After 3 weeks of very low upload speeds (~2Mbps) despite OR visit and tests showing line fault it has synched at 58547 down and 18999 up.
Thinkbroadband speed test http://www.thinkbroadband.com/speedtest/button/143998835411247525046.png
Best figures I have ever seen in nearly 3 years of FTTC. Keeping my fingers crossed that problem was OR Modem
mlmclaren
Looks good and for all we know the connection may improve some more yet Smiley
Nice one!  Wink
Geoff,
York.
ajbrown1965
Had one for several months now, absolutely no problems.
CBR600
Connected my new billion up last night.
disconnected ppp then powered off the router waited a minute then the modem.
Left it for over an hour then connected the billion.
Downstream connection has jumped from 12Mbps to 17Mbps
Upstream no change Sad
Is there anything that can be done at the plusnet end to help my upstream ?
Does anyone know of any tweaks on the billion for more speed ?
ps so my current line speed is now greater than the estimated
Phone exchange:
MEARE HEATH
Estimated line speed:
16Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-07-25 12:39:50
Current line speed:
17.4 Mb
