Billion BiPAC 8800AXL - configuration help
ricke17
Hello people,
I searched the forums and couldn't find anything.
I bought myself a Billion BiPAC 8800AXL and want to configure it to pn - can anyone help me?
Cheers,
Rick.
Fibre Broadband 80/20, Netgear D7000
thunderer
Re: Billion BiPAC 8800AXL - configuration help
http://community.plus.net/forum/index.php/topic,137664.0.html will lead you to this...
In the QUICK START menu:
WAN Interface ( WAN > Wireless )
Main Port = DSL
Layer 2 Interface = PTM (VDSL)
Type = PPPoE
Username = *********@plusdsl.net (******** = your username that you login in with) , You'll enter this on the next screen IIRC.
WAN IP Address = Obtain an IP Address Automatically
Click Continue.
WAN Interface ( WAN > Wireless ) 2nd Screen.
WAN Service.
Type = PPP over Ethernet (PPPoE)
Password = The one you login with.
Service Name = Plusnet (Can be blank)
Authentication Method = CHAP (Can be AUTO, but found it works better if you select CHAP)
IPv4 Address = Static (UNCHECKED, unless you have a static IP)
IP Address = Will be blanked out unless above is checked in which case enter your IP address.
IPv6 for this service = Enable (UNCHECKED)
MTU = 1492
Click Continue & WAIT for about 15-20 seconds, if you've done it all correctly it will connect.
ricke17
Awesome - I think you replied to my question over on Amazon.
Many thanks - this router is coming tomorrow, so am all set to configure it.
So the static IP I enter is the one that pn assigned to me?
Cheers,
Ricardo.
thunderer
Yep. To enter it, just tick the IPv4 Address box & enter it and that should see to it.
DON'T enter a static IP address in your router!
Plusnet don't do static IP addresses in a way that routers understand it - instead they give you a reserved IP address. In other words, leave your router set to obtain IP address automatically / from ISP, and they will always assign you the same one by DHCP.
thunderer
Oh well stand corrected then!  Embarrassed
Do as Jaggies said. Don't do that bit!
ricke17
Cheers guys :-)
