Big variation in Speed
- Big variation in Speed
10-12-2019 4:51 PM
Evening all, Unlimited fibre drops away to slowish speed as the day progresses. Normally pick up the problem at Netflix time etc. Speed test runs the numbers as low as under 10 mbps at times. Turn the router on and off, though, and off it flies back up to 30+ mpbs. It happens daily now. Obviously minimum guaranteed speed is around 30 - but is this symptomatic of local issues. Kids next door playing Fortnite or something, and a big drain on the system? Any views please?
Re: Big variation in Speed
11-12-2019 10:54 AM
Thanks for raising this - I've tested your connection and you're currently in sync at 40mb/s.
Based on the information you've provided, this sounds like a wifi speed issue - could you run a speed test via a wired, ethernet connection and let us know the results?
Best wishes
Dave
11-12-2019 4:46 PM
Thanks Dave - Thanks for testing it. yes it does run fast at times - but falls away sometimes at, what I suppose to be, peak times. Turning the router of and on sends it flying again. The only thing within reach of a cable will be my laptop - next time it happens I'll try that. Regards.
11-12-2019 8:09 PM
Thanks for getting back to us @BertieBassett
No problem, let us know how it goes.
