Big speed drop after moving house
dianemickey33
Hi guys. We moved across town last week and now we're actually closer to our exchange, yet we're only about to get 30-35 down and 7 up. Yet before we was further away and got up to 60 down and 13 up.
 Would it be possible to check our line and see why this is please? Smiley
8 REPLIES 8
Fixes: 418
Re: Big speed drop after moving house
@dianemickey33
As you are on fibre your proximity to the exchange is irrelevant. Your broadband come from a nearby street cabinet, not the exchange. What speed do you get and how does it compare with the expected speeds advised by Plusnet? Alternatively check your expected speed by entering your phone number here.   https://www.broadbandchecker.btwholesale.com/#/ADSL
Techman81
With FTTC it you could be right next door to the exchange but if the cabinet it 2 or 3 streets away then you're going to notice a drop in speed.
ADSL - Closer to exchange the better
FTTC - closer to the cabinet the better
dianemickey33
I think as our phone only got switched on today its showing results from our old house? because when i put our address it shows
but if i use our phone number it says this
So i think that may be incorrect for now?
You guys are right tbh i think it must be a long distance to our cabinet, where ever that is lol
Fixes: 418
@dianemickey33
Such is life! As long as you leave it connected it might improve a bit as the cabinet DLM tunes itself to your line. If you were previously on the fibre extra 80/20 product you will save money if you downgrade to the standard 40/10 fibre service.
dianemickey33
True true, im still very grateful we can at least get fibre here though as it could be much worse. Iv worked out we're like 593m from the cabinet so thats why Sad . Luckily when i spoke to plusnet on the phone when i set up the house move they told me this and said we may as well drop to the lower package so that was decent of them Smiley
dianemickey33
@Baldrick1 Also could i ask, would one of the newer BT master socket faceplates improve speeds much over them old dsl spliters? as when we moved in it had no faceplate so im using one of them old filters lol
Techman81
They virtually do the same job. If your router is directly connected to your master socket via a filter then it probably won't make much difference but they do look tidier.
Fixes: 418
It all depends on whether you have any extension wiring. If you have it's better if you fit a filtered faceplate. They are available from the likes of Amazon. Note that there are two types. One is held on with two screws,  the newer types just clip on. They are not interchangeable.
You can tell if you can get any improvement by fitting one, take the current single socket faceplate off and plug the filter in to the Test socket that you will find in the back box. If this gives you better speed then you should fit a filtered faceplate.
Obviously all speed tests should be conducted using a computer connected to the router with an Ethernet cable.
