Big drop in Download speed
TheChefuk
Hi
In the process of changing from bt landline to plusnet phone line(10th Jan completion date), i have fibre broadband with you already, and have for the last been a broadband customer for the last 10 years. Since the order has been placed ive noticed a drop in speed from a normal speed of 40-50 Mbps(which has been the same since fibre was installed) to speeds as low as 4-6 mbps. I haven't changed my broadband package, just added my phone line. Also my ping has increased massively as well.  This is hard wired direct into the router and laptop, but was getting 40-50 mbps on wirless fine. Please help!!
Cheers
1. Best Effort Test:  -provides background information.
  Download Speed   4.54 Mbps     0 Mbps 38.71 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 4.54 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-38.71 Mbps .
 Additional Information:
 IP Profile for your line is - 38.71 Mbps
2. Upstream Test:  -provides background information.
  Upload Speed   6.32 Mbps     0 Mbps 10 Mbps
Upload speed achieved during the test was - 6.32Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
7 REPLIES 7
TheChefuk
Re: Big drop in Download speed
Does anyone respond to these posts? or is it best to call someone??? Again tonite shocking speed one test as low as 4 Mbps!! Why after so many years of speeds of 35-45 Mbps do i get this?
BrightonRock
Fixes: 8
Welcome to the Forum. Your post might get picked up by one of the Plusnet people here but they can be thin on the ground, particularly at the weekends.
I would be inclined to go through the checks at https://www.plus.net/help/broadband/connection-troubleshooting/ and then report a fault at https://www.plus.net/apps/kbdfaults
LaurenB
Fixes: 131
Hi @TheChefuk I have tested the line and this isn't finding the cause of your issue. I have also checked for congestion and this doesn't look to be the cause either. Could you advise if you are still experiencing slow speeds?
If the issue is still present the next step would be to book an engineer visit. I have updated Ticket: 165598164
 Lauren Barry
TheChefuk
Hi
Yes still very slow 6.24 Mbps tonite. Have responded to the message in my account, with dates for an engineers appointment. Hope this can be sorted very soon...
TheChefuk
Speed today is a lot faster..... done a test an hour since 8am and been getting 36 Mbps, will see how tonite goes.
Fixes: 1,600
I've replied to your thread over here.
Mav
Fixes: 515
Moderator's note:
Thread locked in favour of the link in @Gandalf's post above to keep support in one place.
Forum Moderator and Customer
