Best way to report terrible broadband speeds
Justin4
I have had trouble with dreadful broadband speeds since being with Plusnet. I find contacting them very difficult, Despite plusnet looking as if they are there to help and want to improve the service they make it as hard as possible for you to raise a problem.
Can any one help suggest a way I can send them screen grabs showing that my broadband speed is no where near what they promise so that I can leave them with out being charged?
Thank You
justin4
45 REPLIES 45
Legend
Fixes: 260
Re: Best way to report terrible broadband speeds
See my reply on your previous post.
Justin4
Hey John,
I think my previous post  was erased,  and I have reposted my question in the ADSL broadband  section as you suggested.
cheers
justin4
Legend
Fixes: 260
@Justin4 Your previous post is still there. So, you are on ADSL? In that case can you please post the results fro the following -
BT Broadband - making sure your phone number is not showing, BTW Performance Tester , making sure you run the 'Additional Diagnostics' and the 'Help Desk' page from your Hub, obscuring any personal data?
Fixes: 420
@jab1
The other post states that the guaranteed minimum speed is 31.9Mbps, so has been correctly posted on the fibre  board. Hopefully a Mod will combine the two.
Legend
Fixes: 260
@Baldrick1 The one I am referring to is the recent one in Genera Chat from yesterday, but if the OP has reported the issue previously, it must have been some time ago - I have only been watching the Fibre board for about the last three months or so.
Fixes: 420
@jab1
Yes it was last January.
Fixes: 420
@Justin4
You are causing total confusion posting all over this forum. Hopefully a Mod will pull them together where they belong, that is on the Fibre board.
Whilst a Plusnet staffer might well come along and help you should be aware that the majority of responses that you will get on this forum will be from fellow customers trying to help. We are interested in the technical issues and are unconcerned about your threats to leave. It is therefore probably best if you just concentrate on telling us about your technical issues. It is disappointing that you have not followed this up for the past 10 months as it has clearly been irritating you for all this period.
You need to be aware that for us to help the first thing to do is identify whether you just have a wireless or its a network problem. It is therefore necessary for all initial testing to be done over an Ethernet cable.
When you use this then if the BT speed test does not work then use a different speed teater. Try this one then post the reauslts here. https://www.thinkbroadband.com/speedtest
Also put your phone number in here and post the result:  https://www.broadbandchecker.btwholesale.com/#/ADSL
Justin4
Hey Baldrick1,
Im so sorry I caused total confusion posting all over the forum with my two posts.  I have just tried to get rid of my original post but don't Know how to.
I am very frustrated with Plusnet and surely listening to your customers about how hard it is to resolve problems is a valid point. If you really wanted to help customers and make things better you would look in to this. I don’t want to have to join a forum to sort my broadband out, But It seems the only way. I will keep my frustrations to my self from now on.
Thank you for your suggestions and help, I will Star there.
Legend
Fixes: 260
@Justin4 You have not replied to my post #4 which is in effect the same as @Baldrick1 's - except that I forgot to mention that speed tests should be done over an ethernet (wired) connection.
Justin4
Hey John,
Im sorry o didn’t reply, thank you to you too for your help.
Justin4
Please could you guys tell me where I can find my access line ID?
Legend
Fixes: 260
Don't use that - enter the telephone number in the top box (assuming you are on the BT Broadband site).
Longliner
Seasoned Pro
Fixes: 7
Hello Justin,
Yes, we know slow broadband is very frustrating but complaining about Plusnet staff isn't going to fix it. You have been offered immediate help from two of our most experienced members yet you say you want PN staff to help instead.
Well, there are only four of them and they will get round to assist you, and the first thing they will ask you is to carry out the checks as requested above by John and Baldrick. PN has 1.4 million customers so even if a couple of hundred of them encounter problems it's still an infinitesimal proportion of the satisfied majority who get excellent BB at relatively low prices. (Just don't expect PN email to work, it's rubbish).
Could I suggest you stop moaning, accept this generous offer from your fellow customers and get your BB sorted? Otherwise you might consider changing to another ISP which may offer better service at up to twice the PN price. Good luck whatever you choose.
Justin4
Hey longliner,
I have thanked the members for their suggestions and help. Where have I said I want PN staff to help instead?
