Benefits of Fibre
- Benefits of Fibre
Benefits of Fibre
15-02-2016 3:43 PM
I have a Fibre box right at my gateway, but don't want to bother with it, if it is only for music downloads and films and the like. I don't do any of that
Re: Benefits of Fibre
15-02-2016 3:44 PM
15-02-2016 4:06 PM
15-02-2016 4:08 PM
Quote from: Oldjim unless your adsl speeds are really horrible then you would NOT notice the difference
corrected that for you
15-02-2016 4:12 PM
I remember the change when I went from 512kb fixed to ADSLMax as surfing was much snappier due to the amount of rubbish websites included and it has got worse since
15-02-2016 4:38 PM
15-02-2016 5:20 PM
Quote from: Oldjim and you got it wrong
if their ADSL is not poor (which is what you said), how would changing to fibre be noticeable for surfing and email?
15-02-2016 6:07 PM
How is this taken as meaning "not poor"
Quote from: Oldjim unless your adsl speeds are really horrible then you would notice the diference
15-02-2016 6:12 PM
as i said, and Andrue also said... if the ADSL is NOT poor then noticing a difference when just surfing or email is unlikely.
you said if it's not poor then you would notice a difference.
maybe it's time for your post-dinner nap.
15-02-2016 6:23 PM
I will give here the sequence
You said
Quote if all you do is surf and email then Fibre is not something you would see any benefit from.
To which I replied
Quote unless your adsl speeds are really horrible then you would notice the diference
15-02-2016 7:25 PM
Just checked my speeds, 2.65 download and 0.63 upload, checked 2 sites, and it was near enough on both
I know that speed seems dismal, but on normal surfing it's not too bad
15-02-2016 9:09 PM
mav:quote
15-02-2016 10:01 PM
Let us know some more details on how you connect, what with and what to, there may be simple and cheap ways to improve your speeds.
15-02-2016 10:57 PM
16-02-2016 10:12 AM
