Banding stuck after upgrading to Fibre Extra
FIXED- Subscribe to RSS Feed
- Banding stuck after upgrading to Fibre Extra
4 weeks ago
I have always been on the top level fibre program but last May I was needlessly misled and "upgraded" to the fibre extra, Paying 3 quid more a month for the same service I had anyway To make insult to injury at about the same time my sync DL speed is now stuck at 39999 kbps and has been like that for the last 6 months. Can you please give me a DLM reset. I have asked before but this has not been done yet.
Fixed! Go to the fix.
Re: Banding stuck after upgrading to Fibre Extra
4 weeks ago
I believe you might want this info from the Broadband checker. I have an NTE faceplate (BT ADSL fit then BT VDSL fit). Dialled 170170 Opt 2 and all good.
4 weeks ago
Hi @booji
A connection speed of 39999 kbps could possibly indicate that the circuit is incorrectly provisioned at 40/10.
What are the routers Modem statistics?
Line rate, noise margin, etc
If you are using a Plusnet Hub one router, I believe the stats can be found at: http://192.168.1.254, then click troubleshooting and then help desk.
Please post the results back minus any login details or WiFi names etc and it may provide the first clue as why the speeds are below what you expect.
Regards
Richard
4 weeks ago
Thanks for the reply. I don't think its incorrectly provisioned since I didn't actually go from a product with a different max sync speed. It was a name change only but £3 more! The rate dropped a few weeks after I went the the "new" product. When I first notified PN about the sync drop they confirmed I was stuck on this profile but there was a line fault on the line (which seemed to rectify itself a month later). I think that may be the temporary fault is the reason for the stuck profile.
The main reason for a DLM reset request is that I had higher speeds before. May not seem a lot but 10-15 Mbits can be quite a bit.
I had the BT modem with router combo I ditched ages ago but line stats are as follows.
4 weeks ago
The download noise margin is approx 6dB and yet within the predicted speeds, so the speeds are not limited by Banding. Banding would result in a slower speed with a higher noise margin.
As the line attenuation is low, this is either a very poor Openreach line or there is a high FTTC take up and speeds are signifcantly impacted by crosstalk.
The upstream has "spare" noise margin and should be synching faster.
Whilst it could be coincidental the synch speed of 9997 kbps is suspiciously close to 10000 kbps.
I suspect your line has been provisoned on 40/10.
To be honest unless you need the faster upload speed, I suggest you save the money and downgrade to 40/10.
Regards
Richard
4 weeks ago
Thanks for your help Richard and do not take this the wrong way but I'll wait to see what PN has to say about this.
I would still like a DLM reset before I decide my options. FWIW I asked to go on to the lower rate and PN said they would do this back in June but nothing happened. It seems since the pandemic we just get ignored. As you say either DLM or get downgraded. Since I had previously had higher speeds I would like DLM first and if it stays at 40 then save the money and get downgraded.
Perhaps PN ops could advise?
4 weeks ago
@booji I'm with @RichardB here, I'd be pretty sure, from those line stats, that you're provisioned on a 40/10 connection. However, with only a 6.3db downstream noise margin, I suspect your line isnt going to achieve much more anyway.
My guess what's happened here is confusion between legacy and current products on your product change.
Originally there were two legacy fibre products:
PlusNet Unlimited Fibre - an 80/20 product
Plusnet Fibre - a 40/10 product.
These changed to the current products:
Unlimited Fibre Extra - an 80/20 product
Unlimited Fibre - a 40/10 product.
NB there was also a legacy product ( the name eludes me) which was provisioned on 80/20 but limited to 40/20 by profile. This was later changed to be provisioned on 55/10.
If you've changed from the legacy PlusNet Unlimited Fibre to the current Unlimited Fibre , that would explain the provisioning change to 40/10.
4 weeks ago - last edited 4 weeks ago
Yes MisterW you are right. I was on the old PlusNet Unlimited Fibre 80/20 but "upgraded" to Unlimited Fibre Extra 80/20 and not Unlimited Fibre for £3 more, at which point shortly after the upgrade I got band stuck. That's why I wasn't too pleased with paying more but with a lower service 40/10 . This was all back in May when PN was all in lockdown so I let things settle (well if you can say that in the middle of a second wave is all good but that's another topic for discussion). I have rang PN today and they are removing the banding. As you say it may not make a lot of difference since the SNR is 6db anyway but I normally tweak this at this end to get a bit higher throughput at the expense of a a few Meg upload.
Either way I'll know whether to downgrade to Unlimited Fibre or not. Since it's now being dealt with I'll end the post.
4 weeks ago
@booji I have my doubts... If @RichardB and I are correct , PlusNet will need to place an order with BT Openreach to reprovision the line to 80/20 rather than request a DLM reset to remove any banding.
Let us know how it get's resolved please as the information will help us advise other people in future.
4 weeks ago
Hi @ booji,
Thanks for getting in touch, I appreciate your query and apologise for any inconvenience due to the situation.
I've taken ownership of this for you and will monitor the update from our suppliers and let you know once the issue is resolved.
Please feel free to contact me via the ticket if you have any queries.
Thanks - LF
3 weeks ago
It looks like the banding is removed and I'm happy with the increase in speed.
Hopefully that should be all good now.
