Banded Line
FIXED- Subscribe to RSS Feed
- Re: Banded Line
- « Previous
- 1
- 2
- Next »
Re: Banded Line
02-03-2018 1:48 PM
It looks like your line is still banded.
Profile Name | 0.128M-74M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Unfortunately due to the process being a trial there isn't anything further we can do.
It'd need an engineer to complete a DLM reset. However, as your speeds are above your estimates and we're not finding any issues with your service, it's likely that an engineer will refuse and a call-out charge applied.
Re: Banded Line
02-03-2018 2:10 PM - edited 02-03-2018 2:11 PM
Apart from reporting that the trial process doesn't appear to be fully operational and requesting BT to investigate and possibly completing the task on your behalf whilst they investigate?
Re: Banded Line
02-03-2018 3:12 PM
Can I request that you get Openreach to correct this even if there is a cost to me.
Many thanks
RWW
Re: Banded Line
03-03-2018 9:01 AM
Guys,
Thank you, DLM has finally lifted the banding. The reset worked!
See stats.
RWW
VDSL Training Status: Showtime
Mode: VDSL2 Annex B
VDSL Profile: Profile 17a
G.Vector: Disable
Traffic Type: PTM Mode
Link Uptime: 0 day: 16 hours: 10 minutes
VDSL Port Details Upstream Downstream
Line Rate: 20.033 Mbps 79.998 Mbps
Actual Net Data Rate: 20.000 Mbps 79.999 Mbps
Trellis Coding: ON ON
SNR Margin: 12.2 dB 7.3 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 7.4 dBm 13.8 dBm
Receive Power: -7.1 dBm -3.0 dBm
Actual INP: 0.0 symbols 48.0 symbols
Total Attenuation: 0.0 dB 16.8 dB
Attainable Net Data Rate: 29.491 Mbps 87.566 Mbps
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 6.9 24.1 35.5 N/A N/A 11.7 28.0 43.8
Signal Attenuation(dB): 6.9 22.9 34.6 N/A N/A 14.2 27.8 43.8
SNR Margin(dB): 12.1 12.2 12.1 N/A N/A 7.3 7.3 7.3
TX Power(dBm): -0.3 -19.4 6.5 N/A N/A 11.1 7.8 7.1
Re: Banded Line
03-03-2018 11:47 AM - edited 03-03-2018 11:50 AM
Just for info @RWW I am just a customer like yourself and have no access to Plusnet systems or BT
I hope the DLM reset improves your line performance.
Re: Banded Line
03-03-2018 1:36 PM
My apologies MauriceC, I need to open my eyes...
Line looking good now.
RWW
06-03-2018 3:10 PM
- « Previous
- 1
- 2
- Next »
