Bad Weather - Several Disconnections
pictonat
I must of been totally lucky over spring & summer but as soon as the weather has worsened I'm experiencing a high number of disconnections (or so it seems) .  I reported this last year and believed the disconnection issues to have been fixed because I hadn't noticed any but t his evening the weather has been pretty bad and I can't seem to hold a connection .  Might be an over exaggeration whilst i'm trying to browse the web but could someone check this out please ?
Cheers
Re: Bad Weather - Several Disconnections
Is this FTTC?
pictonat
Yeah . FTTC
You'll need someone from PN to check your line/RADIUS graphs to show the disconnects.
What was the cause last time?
Unfortunately, the bad weather can play havoc with internet connections (particularly if you have overhead wiring).
