Bad Routing To EU?
FrazUK
Bad Routing To EU?
I made a thread recently about problems with UDP bandwidth and gaming. Here is the thread.
I always thought it was something relatively local to me, bad quality line, congestion at the cabinet or exchange, but after some more testing, I've found it isn't such a local problem.
It seems to be a problem with routing to the EU. Running iperf UDP download tests I get masses of out of order packets and packet loss to EU servers as well as packet loss on the upload. I'm using public iperf servers which aren't always up and running, but over the last couple of months I've run tests to France, Germany, and the Netherlands and they all have the same results with packet loss and out-of-order packets at any time of the day, any day of the week. I've also tested on a hand full of American servers which NEVER have any packet loss or out-of-order packets even with tests at much higher bandwidth than those I do to the EU. Tests as low as 0.5mbs to the EU can have out of order packets and packet loss that increases with higher bandwidth. On American servers I can test at 20mbs+ with zero out-of-order packets and 0% packet loss.
All the EU servers I have tested on seem to have one thing in common. a hop through t2c3-et-5-1-2.nl-ams2.gia.bt.net [166.49.208.217]. I never hit this hop for American servers. I'm wondering if this hop is causing routing problems?
I really think it's out of order packets causing the general feeling of "being behind the server" when playing online.
Anyway, since there are no problems for American servers this obviously isn't a local problem or tests anywhere in the world would give the same results so a BT engineer won't be able to fix this.
Below are some poorly formatted test results. The tests to America are at the bottom showing no problems even with much higher bandwidth. There's even less jitter!
Paris
Tracing route to ping.online.net [62.210.18.40]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms BTHomeHub.home [192.168.1.254]
2 10 ms 9 ms 9 ms 252.core.plus.net [195.166.130.252]
3 9 ms 10 ms 10 ms 84.93.253.99
4 10 ms 10 ms 10 ms 195.99.125.134
5 10 ms 10 ms 10 ms core1-hu0-1-0-1-1.southbank.ukcore.bt.net [195.99.127.10]
6 10 ms 10 ms 9 ms 109.159.252.140
7 10 ms 9 ms 10 ms 166-49-209-132.gia.bt.net [166.49.209.132]
8 15 ms 14 ms 15 ms t2c3-et-5-1-2.nl-ams2.gia.bt.net [166.49.208.217]
9 * * * Request timed out.
10 21 ms 21 ms 21 ms 195.154.2.105
11 21 ms 21 ms 21 ms 51.158.1.43
12 21 ms 21 ms 21 ms 45x-s44-2-a9k2.dc3.poneytelecom.eu [195.154.1.107]
13 21 ms 21 ms 21 ms ping.online.net [62.210.18.40]
Trace complete.
iperf3 -c ping.online.net -p 5200 -V -u -b 4M -R
[ ID] Interval Transfer Bandwidth Jitter Lost/Total Datagrams
[ 4] 0.00-1.00 sec 496 KBytes 4.06 Mbits/sec 3.022 ms 0/62 (0%)
[ 4] 1.00-2.00 sec 488 KBytes 4.00 Mbits/sec 2.657 ms 0/61 (0%)
[ 4] 2.00-3.00 sec 488 KBytes 4.00 Mbits/sec 2.779 ms 0/61 (0%)
[ 4] 3.00-4.00 sec 488 KBytes 4.00 Mbits/sec 2.744 ms 0/61 (0%)
[ 4] 4.00-5.00 sec 488 KBytes 3.99 Mbits/sec 2.824 ms 0/61 (0%)
[ 4] 5.00-6.00 sec 488 KBytes 4.00 Mbits/sec 2.831 ms 0/61 (0%)
[ 4] 6.00-7.00 sec 488 KBytes 4.00 Mbits/sec 2.780 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 441 and received packet = 444 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 442 and received packet = 444 AND SP = 4
[ 4] 7.00-8.00 sec 488 KBytes 4.00 Mbits/sec 2.721 ms 2/61 (3.3%)
iperf3: OUT OF ORDER - incoming packet = 503 and received packet = 505 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 504 and received packet = 505 AND SP = 4
[ 4] 8.00-9.00 sec 488 KBytes 4.00 Mbits/sec 2.739 ms 2/61 (3.3%)
[ 4] 9.00-10.00 sec 488 KBytes 4.00 Mbits/sec 2.752 ms 0/61 (0%)
Test Complete. Summary Results:
[ 4] 0.00-10.00 sec 4.77 MBytes 4.00 Mbits/sec 2.752 ms 4/611 (0.65%)
[ 4] Sent 611 datagrams
[SUM] 0.0-10.0 sec 4 datagrams received out-of-order
CPU Utilization: local/receiver 0.5% (0.1%u/0.3%s), remote/sender 0.2% (0.0%u/0.1%s)
iperf Done.
Paris iperf3 -c ping.online.net -p 5200 -V -u -b 4M -R
[ 4] 0.00-1.00 sec 496 KBytes 4.06 Mbits/sec 2.996 ms 0/62 (0%)
[ 4] 1.00-2.00 sec 488 KBytes 4.00 Mbits/sec 2.665 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 148 and received packet = 152 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 149 and received packet = 152 AND SP = 4
[ 4] 2.00-3.00 sec 488 KBytes 4.00 Mbits/sec 2.757 ms 2/61 (3.3%)
[ 4] 3.00-4.00 sec 488 KBytes 4.00 Mbits/sec 2.731 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 265 and received packet = 269 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 266 and received packet = 269 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 267 and received packet = 269 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 268 and received packet = 269 AND SP = 4
[ 4] 4.00-5.00 sec 488 KBytes 4.00 Mbits/sec 2.787 ms 4/61 (6.6%)
[ 4] 5.00-6.00 sec 488 KBytes 4.00 Mbits/sec 2.739 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 388 and received packet = 391 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 389 and received packet = 391 AND SP = 4
[ 4] 6.00-7.00 sec 488 KBytes 4.00 Mbits/sec 2.742 ms 2/61 (3.3%)
[ 4] 7.00-8.00 sec 488 KBytes 4.00 Mbits/sec 2.761 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 514 and received packet = 519 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 515 and received packet = 519 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 516 and received packet = 519 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 517 and received packet = 519 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 518 and received packet = 519 AND SP = 4
[ 4] 8.00-9.00 sec 488 KBytes 4.00 Mbits/sec 2.743 ms 5/61 (8.2%)
iperf3: OUT OF ORDER - incoming packet = 557 and received packet = 562 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 558 and received packet = 562 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 559 and received packet = 562 AND SP = 4
[ 4] 9.00-10.00 sec 488 KBytes 4.00 Mbits/sec 2.742 ms 3/61 (4.9%)
[ 4] 0.00-10.00 sec 4.77 MBytes 4.00 Mbits/sec 2.742 ms 16/611 (2.6%)
[SUM] 0.0-10.0 sec 16 datagrams received out-of-order
CPU Utilization: local/receiver 0.3% (0.1%u/0.2%s), remote/sender 0.1% (0.0%u/0.1%s)
iperf Done.
[ 4] 0.00-1.00 sec 496 KBytes 4.06 Mbits/sec 3.027 ms 0/62 (0%)
[ 4] 1.00-2.00 sec 488 KBytes 4.00 Mbits/sec 2.658 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 154 and received packet = 158 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 155 and received packet = 158 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 156 and received packet = 158 AND SP = 4
[ 4] 2.00-3.00 sec 488 KBytes 4.00 Mbits/sec 2.760 ms 3/61 (4.9%)
[ 4] 3.00-4.00 sec 488 KBytes 4.00 Mbits/sec 2.782 ms 0/61 (0%)
[ 4] 4.00-5.00 sec 488 KBytes 4.00 Mbits/sec 2.851 ms 0/61 (0%)
[ 4] 5.00-6.00 sec 488 KBytes 3.99 Mbits/sec 2.753 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 377 and received packet = 379 AND SP = 4
[ 4] 6.00-7.00 sec 488 KBytes 4.00 Mbits/sec 2.745 ms 1/61 (1.6%)
[ 4] 7.00-8.00 sec 488 KBytes 4.00 Mbits/sec 2.764 ms 0/61 (0%)
[ 4] 8.00-9.00 sec 488 KBytes 4.00 Mbits/sec 2.725 ms 0/61 (0%)
[ 4] 9.00-10.00 sec 488 KBytes 4.00 Mbits/sec 2.724 ms 0/61 (0%)
[ 4] 0.00-10.00 sec 4.77 MBytes 4.00 Mbits/sec 2.724 ms 4/611 (0.65%)
CPU Utilization: local/receiver 0.6% (0.1%u/0.5%s), remote/sender 0.1% (0.0%u/0.1%s)
iperf Done.
Amsterdam
Tracing route to ping-ams1.online.net [163.172.208.7]
3 10 ms 9 ms 9 ms 84.93.253.103
4 10 ms 10 ms 10 ms 195.99.125.138
5 10 ms 10 ms 10 ms 109.159.252.144
6 10 ms 10 ms 9 ms 166-49-209-132.gia.bt.net [166.49.209.132]
7 15 ms 15 ms 15 ms t2c3-et-5-1-2.nl-ams2.gia.bt.net [166.49.208.217]
8 * * * Request timed out.
9 17 ms 16 ms 16 ms 51.158.8.168
10 17 ms 17 ms 17 ms 51.158.143.1
11 16 ms 16 ms 16 ms ping-ams1.online.net [163.172.208.7]
Trace complete.
iperf3 -c ping-ams1.online.net -p 5201 -V -u -b 4M -R
[ 4] 0.00-1.00 sec 496 KBytes 4.06 Mbits/sec 5.418 ms 0/62 (0%)
[ 4] 1.00-2.00 sec 488 KBytes 4.00 Mbits/sec 2.710 ms 0/61 (0%)
[ 4] 2.00-3.00 sec 488 KBytes 4.00 Mbits/sec 2.755 ms 0/61 (0%)
[ 4] 3.00-4.00 sec 488 KBytes 4.00 Mbits/sec 2.800 ms 0/61 (0%)
[ 4] 4.00-5.00 sec 488 KBytes 4.00 Mbits/sec 2.808 ms 1/61 (1.6%)
[ 4] 5.00-6.00 sec 488 KBytes 4.00 Mbits/sec 2.737 ms 0/61 (0%)
[ 4] 6.00-7.00 sec 488 KBytes 4.00 Mbits/sec 2.706 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 442 and received packet = 446 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 443 and received packet = 446 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 444 and received packet = 446 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 445 and received packet = 446 AND SP = 4
[ 4] 7.00-8.00 sec 488 KBytes 4.00 Mbits/sec 2.744 ms 4/61 (6.6%)
[ 4] 8.00-9.00 sec 488 KBytes 4.00 Mbits/sec 2.734 ms 0/61 (0%)
[ 4] 9.00-10.00 sec 488 KBytes 4.00 Mbits/sec 2.763 ms 0/61 (0%)
[ 4] 0.00-10.00 sec 4.77 MBytes 4.00 Mbits/sec 2.763 ms 5/611 (0.82%)
[SUM] 0.0-10.0 sec 5 datagrams received out-of-order
CPU Utilization: local/receiver 0.3% (0.0%u/0.3%s), remote/sender 0.1% (0.0%u/0.1%s)
iperf Done.
Amsterdam iperf3 -c ping-ams1.online.net -p 5201 -V -u -b 4M -R
[ 4] 0.00-1.00 sec 496 KBytes 4.06 Mbits/sec 5.477 ms 0/62 (0%)
iperf3: OUT OF ORDER - incoming packet = 93 and received packet = 98 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 94 and received packet = 98 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 95 and received packet = 98 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 96 and received packet = 98 AND SP = 4
[ 4] 1.00-2.00 sec 488 KBytes 4.00 Mbits/sec 2.739 ms 4/61 (6.6%)
[ 4] 3.00-4.00 sec 488 KBytes 4.00 Mbits/sec 2.767 ms 0/61 (0%)
[ 4] 4.00-5.00 sec 488 KBytes 4.00 Mbits/sec 2.783 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 307 and received packet = 312 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 308 and received packet = 312 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 309 and received packet = 312 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 310 and received packet = 312 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 311 and received packet = 312 AND SP = 4
[ 4] 5.00-6.00 sec 488 KBytes 4.00 Mbits/sec 2.750 ms 5/61 (8.2%)
[ 4] 6.00-7.00 sec 488 KBytes 4.00 Mbits/sec 2.748 ms 0/61 (0%)
[ 4] 7.00-8.00 sec 488 KBytes 4.00 Mbits/sec 2.750 ms 0/61 (0%)
[ 4] 8.00-9.00 sec 488 KBytes 4.00 Mbits/sec 2.769 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 569 and received packet = 574 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 570 and received packet = 574 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 571 and received packet = 574 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 572 and received packet = 574 AND SP = 4
[ 4] 9.00-10.00 sec 488 KBytes 4.00 Mbits/sec 2.744 ms 4/61 (6.6%)
[ 4] 0.00-10.00 sec 4.77 MBytes 4.00 Mbits/sec 2.744 ms 13/611 (2.1%)
[SUM] 0.0-10.0 sec 13 datagrams received out-of-order
CPU Utilization: local/receiver 0.8% (0.6%u/0.1%s), remote/sender 0.0% (0.0%u/0.0%s)
iperf Done.
[ 4] 0.00-1.00 sec 496 KBytes 4.06 Mbits/sec 5.440 ms 0/62 (0%)
[ 4] 1.00-2.00 sec 488 KBytes 4.00 Mbits/sec 2.748 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 172 and received packet = 176 AND SP = 4
[ 4] 2.00-3.00 sec 488 KBytes 4.00 Mbits/sec 2.797 ms 1/61 (1.6%)
[ 4] 3.00-4.00 sec 488 KBytes 4.00 Mbits/sec 2.739 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 276 and received packet = 280 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 277 and received packet = 280 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 278 and received packet = 280 AND SP = 4
[ 4] 4.00-5.00 sec 488 KBytes 3.99 Mbits/sec 2.787 ms 3/61 (4.9%)
[ 4] 5.00-6.00 sec 504 KBytes 4.13 Mbits/sec 3.053 ms 0/63 (0%)
iperf3: OUT OF ORDER - incoming packet = 392 and received packet = 395 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 393 and received packet = 395 AND SP = 4
[ 4] 6.00-7.00 sec 472 KBytes 3.86 Mbits/sec 2.731 ms 2/59 (3.4%)
[ 4] 7.00-8.00 sec 488 KBytes 4.00 Mbits/sec 2.740 ms 0/61 (0%)
iperf3: OUT OF ORDER - incoming packet = 503 and received packet = 507 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 504 and received packet = 507 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 505 and received packet = 507 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 506 and received packet = 507 AND SP = 4
[ 4] 8.00-9.00 sec 488 KBytes 4.00 Mbits/sec 2.748 ms 4/61 (6.6%)
[ 4] 9.00-10.00 sec 488 KBytes 4.00 Mbits/sec 2.739 ms 0/61 (0%)
[ 4] 0.00-10.00 sec 4.77 MBytes 4.00 Mbits/sec 2.739 ms 10/611 (1.6%)
[SUM] 0.0-10.0 sec 10 datagrams received out-of-order
CPU Utilization: local/receiver 0.9% (0.6%u/0.3%s), remote/sender 0.1% (0.0%u/0.1%s)
iperf Done.
Amsterdam iperf3 -c ping-ams1.online.net -p 5201 -V -u -b 10M -R
Starting Test: protocol: UDP, 1 streams, 8192 byte blocks, omitting 0 seconds, 10 second test
[ 4] 0.00-1.00 sec 1.20 MBytes 10.0 Mbits/sec 2.708 ms 0/153 (0%)
[ 4] 1.00-2.00 sec 1.20 MBytes 10.0 Mbits/sec 2.656 ms 0/153 (0%)
iperf3: OUT OF ORDER - incoming packet = 398 and received packet = 403 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 399 and received packet = 403 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 400 and received packet = 403 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 401 and received packet = 403 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 402 and received packet = 403 AND SP = 4
[ 4] 2.00-3.00 sec 1.19 MBytes 9.96 Mbits/sec 2.687 ms 5/152 (3.3%)
[ 4] 3.00-4.00 sec 1.20 MBytes 10.0 Mbits/sec 2.723 ms 0/153 (0%)
iperf3: OUT OF ORDER - incoming packet = 643 and received packet = 648 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 644 and received packet = 649 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 645 and received packet = 650 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 646 and received packet = 650 AND SP = 4
[ 4] 4.00-5.00 sec 1.19 MBytes 9.96 Mbits/sec 2.639 ms 5/153 (3.3%)
iperf3: OUT OF ORDER - incoming packet = 768 and received packet = 778 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 769 and received packet = 778 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 770 and received packet = 778 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 771 and received packet = 778 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 887 and received packet = 893 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 888 and received packet = 893 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 889 and received packet = 893 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 902 and received packet = 904 AND SP = 4
[ 4] 5.00-6.00 sec 1.18 MBytes 9.91 Mbits/sec 2.650 ms 9/152 (5.9%)
[ 4] 6.00-7.00 sec 1.20 MBytes 10.0 Mbits/sec 2.635 ms 0/153 (0%)
iperf3: OUT OF ORDER - incoming packet = 1124 and received packet = 1128 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1125 and received packet = 1128 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1126 and received packet = 1128 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1127 and received packet = 1128 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1139 and received packet = 1145 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1140 and received packet = 1145 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1141 and received packet = 1145 AND SP = 4
[ 4] 7.00-8.00 sec 1.18 MBytes 9.90 Mbits/sec 2.705 ms 8/152 (5.3%)
iperf3: OUT OF ORDER - incoming packet = 1238 and received packet = 1244 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1239 and received packet = 1244 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1240 and received packet = 1244 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1241 and received packet = 1244 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1319 and received packet = 1325 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1320 and received packet = 1325 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1321 and received packet = 1325 AND SP = 4
iperf3: OUT OF ORDER - incoming packet = 1322 and received packet = 1325 AND SP = 4
[ 4] 8.00-9.00 sec 1.20 MBytes 10.0 Mbits/sec 2.739 ms 8/153 (5.2%)
[ 4] 9.00-10.00 sec 1.19 MBytes 9.97 Mbits/sec 2.708 ms 0/152 (0%)
[ 4] 0.00-10.00 sec 11.9 MBytes 10.0 Mbits/sec 2.708 ms 35/1526 (2.3%)
[ 4] Sent 1526 datagrams
[SUM] 0.0-10.0 sec 32 datagrams received out-of-order
CPU Utilization: local/receiver 0.8% (0.3%u/0.5%s), remote/sender 0.3% (0.0%u/0.3%s)
iperf Done.
California
Tracing route to iperf.scottlinux.com [45.33.39.39]
3 10 ms 10 ms 11 ms 84.93.253.103
5 11 ms 10 ms 11 ms 195.99.127.68
6 10 ms 9 ms 10 ms 166-49-209-132.gia.bt.net [166.49.209.132]
7 10 ms 10 ms 11 ms 212.119.4.140
8 11 ms 11 ms 11 ms ae-7.r20.londen12.uk.bb.gin.ntt.net [129.250.4.140]
9 11 ms 11 ms 14 ms ae-1.r21.londen12.uk.bb.gin.ntt.net [129.250.2.183]
10 90 ms 84 ms 85 ms ae-13.r25.asbnva02.us.bb.gin.ntt.net [129.250.2.111]
11 84 ms 85 ms 85 ms ae-1.r24.asbnva02.us.bb.gin.ntt.net [129.250.2.37]
12 150 ms 149 ms 149 ms ae-2.r24.snjsca04.us.bb.gin.ntt.net [129.250.6.237]
13 143 ms 143 ms 142 ms ae-40.r02.snjsca04.us.bb.gin.ntt.net [129.250.3.121]
14 153 ms 151 ms 151 ms ce-0-18-0-1.r02.snjsca04.us.ce.gin.ntt.net [192.80.17.170]
15 141 ms 140 ms 140 ms 173.230.159.67
16 161 ms 161 ms 161 ms iperf.scottlinux.com [45.33.39.39]
Trace complete.
iperf3 -c iperf.scottlinux.com -p 5201 -V -u -b 20M -R
[ 4] 0.00-1.00 sec 2.46 MBytes 20.6 Mbits/sec 158.639 ms 0/315 (0%)
[ 4] 1.00-2.00 sec 2.39 MBytes 20.0 Mbits/sec 0.154 ms 0/306 (0%)
[ 4] 2.00-3.00 sec 2.38 MBytes 20.0 Mbits/sec 0.228 ms 0/305 (0%)
[ 4] 3.00-4.00 sec 2.38 MBytes 20.0 Mbits/sec 0.157 ms 0/305 (0%)
[ 4] 4.00-5.00 sec 2.38 MBytes 20.0 Mbits/sec 0.182 ms 0/305 (0%)
[ 4] 5.00-6.00 sec 2.39 MBytes 20.1 Mbits/sec 0.175 ms 0/306 (0%)
[ 4] 6.00-7.00 sec 2.38 MBytes 20.0 Mbits/sec 0.147 ms 0/305 (0%)
[ 4] 7.00-8.00 sec 2.38 MBytes 20.0 Mbits/sec 0.140 ms 0/305 (0%)
[ 4] 8.00-9.00 sec 2.38 MBytes 20.0 Mbits/sec 0.206 ms 0/305 (0%)
[ 4] 9.00-10.00 sec 2.38 MBytes 20.0 Mbits/sec 0.239 ms 0/305 (0%)
[ 4] 0.00-10.00 sec 24.3 MBytes 20.4 Mbits/sec 0.366 ms 0/3109 (0%)
[ 4] Sent 3109 datagrams
CPU Utilization: local/receiver 1.5% (1.0%u/0.4%s), remote/sender 2.0% (0.1%u/1.8%s)
iperf Done.
[ 4] 0.00-1.00 sec 2.46 MBytes 20.6 Mbits/sec 158.672 ms 0/315 (0%)
[ 4] 1.00-2.00 sec 2.39 MBytes 20.0 Mbits/sec 0.139 ms 0/306 (0%)
[ 4] 2.00-3.00 sec 2.38 MBytes 20.0 Mbits/sec 0.168 ms 0/305 (0%)
[ 4] 3.00-4.00 sec 2.38 MBytes 20.0 Mbits/sec 0.164 ms 0/305 (0%)
[ 4] 5.00-6.00 sec 2.38 MBytes 20.0 Mbits/sec 0.167 ms 0/305 (0%)
[ 4] 6.00-7.00 sec 2.39 MBytes 20.0 Mbits/sec 0.150 ms 0/306 (0%)
[ 4] 7.00-8.00 sec 2.38 MBytes 20.0 Mbits/sec 0.151 ms 0/305 (0%)
[ 4] 8.00-9.00 sec 2.38 MBytes 20.0 Mbits/sec 0.121 ms 0/305 (0%)
[ 4] 9.00-10.00 sec 2.38 MBytes 20.0 Mbits/sec 0.126 ms 0/305 (0%)
[ 4] 0.00-10.00 sec 24.3 MBytes 20.4 Mbits/sec 0.217 ms 0/3111 (0%)
[ 4] Sent 3111 datagrams
CPU Utilization: local/receiver 1.3% (0.4%u/0.9%s), remote/sender 1.8% (0.0%u/1.8%s)
iperf Done.
[ 4] 0.00-1.00 sec 2.48 MBytes 20.7 Mbits/sec 139.483 ms 0/317 (0%)
[ 4] 1.00-2.00 sec 2.38 MBytes 20.0 Mbits/sec 0.205 ms 0/305 (0%)
[ 4] 2.00-3.00 sec 2.38 MBytes 20.0 Mbits/sec 0.141 ms 0/305 (0%)
[ 4] 3.00-4.00 sec 2.39 MBytes 20.0 Mbits/sec 0.232 ms 0/306 (0%)
[ 4] 4.00-5.00 sec 2.38 MBytes 19.9 Mbits/sec 0.133 ms 0/304 (0%)
[ 4] 5.00-6.00 sec 2.39 MBytes 20.0 Mbits/sec 0.179 ms 0/306 (0%)
[ 4] 6.00-7.00 sec 2.38 MBytes 20.0 Mbits/sec 0.182 ms 0/305 (0%)
[ 4] 7.00-8.00 sec 2.38 MBytes 20.0 Mbits/sec 0.163 ms 0/305 (0%)
[ 4] 8.00-9.00 sec 2.38 MBytes 20.0 Mbits/sec 0.207 ms 0/305 (0%)
[ 4] 9.00-10.00 sec 2.39 MBytes 20.0 Mbits/sec 0.120 ms 0/306 (0%)
[ 4] 0.00-10.00 sec 24.3 MBytes 20.4 Mbits/sec 0.116 ms 0/3113 (0%)
[ 4] Sent 3113 datagrams
CPU Utilization: local/receiver 1.6% (1.0%u/0.6%s), remote/sender 2.2% (0.0%u/2.2%s)
iperf Done.
[ 4] 0.00-1.00 sec 2.46 MBytes 20.6 Mbits/sec 158.652 ms 0/315 (0%)
[ 4] 1.00-2.00 sec 2.38 MBytes 20.0 Mbits/sec 0.187 ms 0/305 (0%)
[ 4] 2.00-3.00 sec 2.39 MBytes 20.1 Mbits/sec 0.126 ms 0/306 (0%)
[ 4] 3.00-4.00 sec 2.38 MBytes 20.0 Mbits/sec 0.294 ms 0/305 (0%)
[ 4] 4.00-5.00 sec 2.38 MBytes 20.0 Mbits/sec 0.162 ms 0/305 (0%)
[ 4] 5.00-6.00 sec 2.38 MBytes 20.0 Mbits/sec 0.241 ms 0/305 (0%)
[ 4] 6.00-7.00 sec 2.38 MBytes 20.0 Mbits/sec 0.158 ms 0/305 (0%)
[ 4] 7.00-8.00 sec 2.39 MBytes 20.1 Mbits/sec 0.156 ms 0/306 (0%)
[ 4] 8.00-9.00 sec 2.38 MBytes 19.9 Mbits/sec 0.157 ms 0/304 (0%)
[ 4] 9.00-10.00 sec 2.39 MBytes 20.1 Mbits/sec 0.122 ms 0/306 (0%)
[ 4] 0.00-10.00 sec 24.3 MBytes 20.4 Mbits/sec 0.105 ms 0/3111 (0%)
CPU Utilization: local/receiver 0.6% (0.6%u/0.0%s), remote/sender 1.9% (0.1%u/1.8%s)
iperf Done.
