Back with Plusnet on fibre plus
welshviking1
Hi, After many years with Sky I have returned to Plusnet and I am on Fibre Plus. I was with Plusnet many years ago in the age of non-fibre but after being messed around by sky lately I have had enough. I am not 100% sure what speed I should be getting and if there is an easy way of checking it but this is what I am getting at the moment in my 1st hour back (see below). Any suggestions on speed or advice would be very much appreciated....Regards Colin
BT Wholesale Broadband Performance Test
download 40.99
upload 6.21
ping 25.25
Moderator's note by Mike (Mav): All caps title edited as per Forum rules.
Fixes: 114
Re: Back with Plusnet on fibre plus
Welcome back.
I can see we estimated your speeds at between 35Mb and 47.5Mb. At the moment they are within the estimates for your line.
 Matthew Wheeler
SpendLessTime
Aspiring Hero
Fixes: 53
@welshviking1
Welcome to the forums.
For future reference you can check your own estimates by using http://www.dslchecker.bt.com/adsl/adslchecker.welcome?
And the BT Speedtest further diagnostics opinion will tell you the line's IP profile details.
welshviking1
Thanks for the reply Matthew, are the speeds likely to get any better (upload and download) or am I at the best I am likely to get....Cheers
Fixes: 168
They could potentially increase, as DLM (Dynamic Line Management) will monitor the line and try to make adjustments to give the highest speed while still remaining stable.
Having said this, it will largely be out of our control if/when this happens.
 Harry Beesley
