BTw Performance Test via Further Diagnostics
- BTw Performance Test via Further Diagnostics
Re: BTw Performance Test via Further Diagnostics
03-02-2015 5:49 PM
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 8.9 14.8
Attenuation (dB) 11.3 0.0
Output Power (dBm) 12.4 -1.2
Attainable Rate (Kbps) 90425 32349
Rate (Kbps) 79987 19999
03-02-2015 5:53 PM
As you monitor your line stats minute by minute (or maybe even second by second), I'm sure you would be asking the CRT staff for an explanation if your sync speed was to drop.
03-02-2015 6:02 PM
@ AndyH I have to kept an eyes on that one:
If it went down to 79987 then my sync rate will fall down?
03-02-2015 11:04 PM
Also, as your sync rate hasn't changed then neither will your IP Profile have changed
04-02-2015 3:42 AM
It's important we find out what's causing the issue, however, it's out of our hands, it's with BT.
04-02-2015 11:32 AM
05-02-2015 10:28 PM
It's appear that BTw PT are working now. See below screenshot.
06-02-2015 1:04 AM
06-02-2015 9:51 AM
EDIT: Still not working here...
06-02-2015 10:15 AM
06-02-2015 11:46 AM
Quote from: thesawdust lock this thread quick
No, That's up to me. It's my thread who I have started this page. So, I leave this open as few others still have this problem.
06-02-2015 7:05 PM
06-02-2015 8:05 PM
Quote from: goldenfibre No, That's up to me. .......
Actually, it would be up to the mods. As others are still having problems, I doubt it would be locked, the mods apply a bit of common sense you know
12-02-2015 11:41 AM
12-02-2015 12:54 PM
