BTW IP Profile download speed again.
- BTW IP Profile download speed again.
08-09-2016 11:58 AM
Once again my BTW ip profile line speed has dropped. Can anyone at plusnet tell me why this is happening?
It used to be 63Mbps. For 4 years no problem at all. Then i changed my phone line to Pn took out pn tv and renewed my BB contract for another 2 years.
From then on my bt line speed has been slowly dropping from 63Mbps. It just gone down again. Now it's 55Mbps.
I have asked this question before but never got a straight answer. Getting really fed up now as no one at PN can or will answer this for me. So can anyone on the forum here come up with an answer for me please
Re: BTW IP Profile download speed again.
on 08-09-2016 12:11 PM - last edited on 08-09-2016 12:16 PM by Strat
OK just done a re boot of the router and btw line speed up to 59 Mbps.
What is it with the hub1 router that you keep having to re boot the thing every few days to keep you speed up.
Does anyone know of another router that will work with plusnet and youview tv out of the box because the hub 1 router is [-Censored-]
Moderator's note by Dick (Strat) Avoidance of swear filter removed.
08-09-2016 12:37 PM
Friend said he had the same problem with the hub i bought off ebay (was not paying plusnet 120 odd ty)
TP-LINK TD-W9980 works well only costs 60 pound as well ..
08-09-2016 1:32 PM
The speed will change based on the DLM equipments monitoring of the line. It will move up or down depending on whether the line is stable or not and make changes accordingly.
08-09-2016 4:22 PM
My line was stable for 4 years with no problem at all. Problems only started after installing hub 1 router. Looking at other posts on here it would seem that the hub1 has an inherant fault. I guess i'll just have to spend a small fortune on a decent router to be able to get my stable speeds back up again. By the way, my old Netgear router doesn't support iptv so i can't use that
