BT line profile reset?
scotland731
I have just been upgraded to the 50\10 however although the profile on the BT wholesale speedtester shows my upload profile has changed however the download has not changed.
Is this an error or a limitation with my line?
Fixes: 167
Re: BT line profile reset?
Testing your line is reporting a potential fault, I'm not sure if we'll be able to get your speed increased but it might be worth reporting a speed fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
scotland731
Thanks Chris, I have recently had an engineer out after a weekend where my line dropped constantly and my speed was reduced to 20MB, the engineer could see no faults at the time and reset my profile to get me back up to full speed.
Are you able to provide any more info as I have had issues previously when logging a fault due my connection not dropping enough to have BT take a look.
scotland731
Ticket logged Thumbs Up
Question #131749887
Fixes: 167
@scotland731
Your fault report has been automatically sent to our suppliers and was assigned to an engineer to investigate earlier today. We'll check back for updates and let you know when we get them.
 Chris Parr
 Plusnet Staff
scotland731
Thanks for the update Chris, it's much appreciated Thumbs Up
scotland731
Have you had any updates from BT? my download profile is still set to 34 MB
