BT home Hub 4 vs Plusnet Sagecom Router
Eserim
OK - from ebay I can get a refurb BT Home Hub 4R for £20 - it is dual band where as the Sagecom isn't.  What's the opinion here - is £20 worth it for the few extra features?
Cheers
Eserim
Fixes: 36
Re: BT home Hub 4 vs Plusnet Sagecom Router
The Home Hub 5 would be a better option with its built in VDSL modem, dual band wireless is worth the extra speed, less congestion if your wireless devices support it.
Eserim
Smiley Ah, but can I get a 5 for £20?
Eserim
Eserim
Angry  Reading up on Home Hubs and no easy way to change DNS - Grrrrrrrr
Champnet
Having used the home hub 4, 5a & 5b I don't remember any problems with DNS settings.
First search on Google shows how to change setting from auto to manual............
Eserim
You mean that first post where someone says how to do it, only for someone else to point out "BUSINESS hub, not HOME hub!"    https://community.bt.com/t5/Connected-Devices-Other/Manual-DNS-settings-please-for-home-hub-5/td-p/1...; ?
Most other Google hits say it isn't possible to set custom DNS, like https://community.bt.com/t5/Connected-Devices-Other/Changing-default-DNS-Server/td-p/191215/page/4
Champnet
Reckon restrictions only apply when connected to BT ISP.
There's an excellent sticky thread by NorthEasterner at the top of this Fibre section
