BT home Hub 4 vs Plusnet Sagecom Router
- Re: BT home Hub 4 vs Plusnet Sagecom Router
19-12-2015 12:31 PM
OK - from ebay I can get a refurb BT Home Hub 4R for £20 - it is dual band where as the Sagecom isn't. What's the opinion here - is £20 worth it for the few extra features?
Cheers
Eserim
Cheers
Eserim
Message 1 of 8
(1,785 Views)
7 REPLIES 7
19-12-2015 1:17 PM
The Home Hub 5 would be a better option with its built in VDSL modem, dual band wireless is worth the extra speed, less congestion if your wireless devices support it.
Message 2 of 8
(1,020 Views)
19-12-2015 2:49 PM
Ah, but can I get a 5 for £20?
Message 3 of 8
(1,020 Views)
19-12-2015 2:50 PM
Message 4 of 8
(1,020 Views)
19-12-2015 5:15 PM
Reading up on Home Hubs and no easy way to change DNS - Grrrrrrrr
Message 5 of 8
(1,020 Views)
19-12-2015 5:29 PM
Having used the home hub 4, 5a & 5b I don't remember any problems with DNS settings.
First search on Google shows how to change setting from auto to manual............
Message 6 of 8
(1,020 Views)
19-12-2015 6:23 PM
You mean that first post where someone says how to do it, only for someone else to point out "BUSINESS hub, not HOME hub!" https://community.bt.com/t5/Connected-Devices-Other/Manual-DNS-settings-please-for-home-hub-5/td-p/1...; ?
Most other Google hits say it isn't possible to set custom DNS, like https://community.bt.com/t5/Connected-Devices-Other/Changing-default-DNS-Server/td-p/191215/page/4
Message 7 of 8
(1,020 Views)
19-12-2015 7:16 PM
Reckon restrictions only apply when connected to BT ISP.
There's an excellent sticky thread by NorthEasterner at the top of this Fibre section
Message 8 of 8
(1,020 Views)
