BT Wholesale Test lies
- BT Wholesale Test lies
03-11-2015 9:33 PM
I didn't believe that BTW were "optimising" test results. How is this possible?
Message 1 of 2
(656 Views)
1 REPLY 1
Re: BT Wholesale Test lies
05-11-2015 2:49 PM
Their speed tester is set up to give a higher result than your actual throughput ,so that it is less likely to offer the next pat of the test TAP3 which is used by the isp as evidence of a throughput issue when they raise it with BTW,
BT fakery
adie:quote
BT fakery
adie:quote
Message 2 of 2
(330 Views)
