BT Wholesale Broadband Performance Test no longer work
- BT Wholesale Broadband Performance Test no longer ...
15-11-2017 9:19 PM
@scrookes It's now no longer work for the last 48 hours. Can't check IP Profile rate from BTw system. Bloody fed up and peeled off it. The same happen as before here: https://community.plus.net/t5/Fibre-Broadband/BTw-Performance-Test-via-Further-Diagnostics/m-p/11936... and this: https://community.plus.net/t5/Fibre-Broadband/BT-Wholesale-Broadband-Performance-Test/m-p/1380940#M4...
Re: BT Wholesale Broadband Performance Test no longer work
15-11-2017 9:27 PM
15-11-2017 11:05 PM - edited 15-11-2017 11:06 PM
Which site are you using? Google Chrome, Firefox Quantum or Microsoft Edge?
If you click further diagnostics and IP Profile will not show up.
Just straight to this:
16-11-2017 7:20 AM
There is a problem with Firefox and flash for the BTW test ,, Firefox support told me to tell BT to change their test to HTML
16-11-2017 8:58 AM
16-11-2017 9:57 AM
Try this http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
It might take 5/6/7+ goes but it will work eventually..
16-11-2017 10:08 AM - edited 16-11-2017 10:08 AM
Not working for me either after numerous attempts. Firefox.
"Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information."
16-11-2017 10:09 AM
I use chrome and it can take a lot of attempts but it does finally do it.
16-11-2017 11:15 AM
I try it on chrome for about 12 times attempt but doesn't work. BTw speedtest is unfit for purpose. Bloody BT.
16-11-2017 11:24 AM
Just updated to FF58 , still no better BTW is poop
17-11-2017 1:25 PM
@Gandalf any latest from BTw respond yet? Still not working. Also someone posted as well below:
http://forum.kitz.co.uk/index.php/topic,20577.0.html
tiffy last post was The BT WS Performance Tester (further diagnostics) or the "mouselike.org" facilities are still not working, can't get access to BRAS profiles, as "adslmax" has advised, there is quite a long thread regarding this issue on the PN forum, a staff member has advised he will report to "their suppliers", no feedback to date.
Some PN forum members are reporting that the BT WS checker will work sometimes after multiple attempts, various browsers have been tried by all accepting that there are known speed reporting anomalies with Firefox.
Is this anomaly possibly peculiar to one ISP or is BT the common factor ?
Any other forum members with different ISP's had the same issues ?
17-11-2017 5:59 PM
A kitz forum member using BT ISP has reported that he has had the same issue for a few days so does not seem to be PN users only who are experiencing this anomaly.
17-11-2017 8:13 PM - edited 17-11-2017 8:14 PM
Nothing yet I'm afraid. You'll be the one of the first to know when I hear back.
17-11-2017 11:08 PM
Quite a lot of further feed back from members of the kitz forum, it's certainly more than BT & PN that are effected, in fact only members to date reporting that the system consistantly works are with BT Business and A&A ISP's..
17-11-2017 11:10 PM
@tiffy Best to wait until Monday to see if BTw has response to PN
