BT Wholesale Broadband Performance Test no longer work
goldenfibre
Seasoned Pro
Fixes: 12
 @scrookes It's now no longer work for the last 48 hours. Can't check IP Profile rate from BTw system. Bloody fed up and peeled off it. The same happen as before here: https://community.plus.net/t5/Fibre-Broadband/BTw-Performance-Test-via-Further-Diagnostics/m-p/11936... and this: https://community.plus.net/t5/Fibre-Broadband/BT-Wholesale-Broadband-Performance-Test/m-p/1380940#M4...
83 REPLIES 83
Gel
Aspiring Champion
Fixes: 29
Re: BT Wholesale Broadband Performance Test no longer work
Try with alternative browser; Flash content is an issue for some browsers. Site is working for me, but not using IE11.
goldenfibre
Seasoned Pro
Fixes: 12
Which site are you using? Google Chrome, Firefox Quantum or Microsoft Edge?
If you click further diagnostics and IP Profile will not show up.
Just straight to this:
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 67.18 Mbps
2. Upstream Test:
Upload Speed : 18.14 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
rongtw
Fixes: 12
There is a problem with Firefox and flash for the BTW test ,, Firefox support told me to tell BT to change their test to HTML Undecided
Fixes: 1,600
I've passed this on to our suppliers to investigate.
We'll be in touch when we know more.
benfphillips
Try this http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
It might take 5/6/7+ goes but it will work eventually..
newagetraveller
Not working for me either after numerous attempts. Firefox.
"Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information."
benfphillips
I use chrome and it can take a lot of attempts but it does finally do it.
goldenfibre
Seasoned Pro
Fixes: 12
I try it on chrome for about 12 times attempt but doesn't work. BTw speedtest is unfit for purpose. Bloody BT.
rongtw
Fixes: 12
Just updated to FF58 , still no better BTW is poop
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf  any latest from BTw respond yet? Still not working. Also someone posted as well below:
http://forum.kitz.co.uk/index.php/topic,20577.0.html
tiffy last post was The BT WS Performance Tester (further diagnostics) or the "mouselike.org" facilities are still not working, can't get access to BRAS profiles, as "adslmax" has advised, there is quite a long thread regarding this issue on the PN forum, a staff member has advised he will report to "their suppliers", no feedback to date.
Some PN forum members are reporting that the BT WS checker will work sometimes after multiple attempts, various browsers have been tried by all accepting that there are known speed reporting anomalies with Firefox.
Is this anomaly possibly peculiar to one ISP or is BT the common factor ?
Any other forum members with different ISP's had the same issues ?
tiffy
A kitz forum member using BT ISP has reported that he has had the same issue for a few days so does not seem to be PN users only who are experiencing this anomaly.
Fixes: 1,600
Nothing yet I'm afraid. You'll be the one of the first to know when I hear back.
tiffy
Quite a lot of further feed back from members of the kitz forum, it's certainly more than BT & PN that are effected, in fact only members to date reporting that the system consistantly works are with BT Business and A&A ISP's..
goldenfibre
Seasoned Pro
Fixes: 12
@tiffy Best to wait until Monday to see if BTw has response to PN
