BT Wholesale Broadband Performance Test Faulty
FIXED- Subscribe to RSS Feed
- BT Wholesale Broadband Performance Test Faulty
Re: BT Wholesale Broadband Performance Test Faulty
10-02-2017 9:59 AM
Further diagnostics working for me this morning
10-02-2017 10:14 AM - edited 10-02-2017 11:16 AM
For those that can get it to work... (works on W7 via IE, gives a browser session time out using W10 via Edge)
Is anybody seeing very low download results?
1. Best Effort Test: -provides background information.
Download Speed | |
9.4 Mbps |
0 Mbps | 22.08 Mbps Max Achievable Speed |
Download speedachieved during the test was - 9.4 Mbps For your connection, the acceptable range of speedsis 20 Mbps-22.08 Mbps . Additional Information: IP Profile for your line is - 22.08 Mbps |
Upload Speed | |
1.81 Mbps |
0 Mbps | 2 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 1.81Mbps Additional Information: Upstream Rate IP profile on your line is - 2 Mbps |
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
(It was very hit and miss through the night!!)
edit at 11:10. Could not get Edge, Chrome or Firefox (the latter is down to FF itself) via W10 to work on the tester. They gave the browser timed out message.
However, after multiple attempts on the W7 laptop, after changing BB username to speedtest@speedtest_domain, test did not show and final results, changed router back to <username>@plusdsl.net and the very next test gave Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
There are no results to be seen!!
10-02-2017 12:53 PM
@scrookes Can you please check to see if there are two speedtest@speedtest_domain test results showing at your end for my connection?
The reason for asking, is that the first part of the test is giving me very erratic download test results, which tbh I thought others on this thread would have been reporting the same too by now. I know strat mentioned his upload being incorrect.
The second test, using W7 and IE now either goes to browser timed out* or it works and gives me the third test
*the same as any browser on W10.
The third test, after changing router username goes to this address - http://test3.speedtest.btwholesale.com/PerformanceTesterWS/indexTap3Frames.jsp?BBIP=<my number removed>&serviceId=&TAP=3&BBD= but both times I have the following message, so I don't know if they are working ...:( - I have cleared all cache, cookies etc between all of my attempts so doubt the following is being generated at my end -
The browser session has timed out. Please refresh the main Performance Tester page.
10-02-2017 2:01 PM
Sure, bear with me.
10-02-2017 2:08 PM
PM'd you the results
10-02-2017 2:10 PM
@DS Or not. You mind if I post them here?
on 10-02-2017 3:08 PM - last edited on 10-02-2017 5:06 PM by Mav
Sorry about that, been on the phone to yourselves and missed the replies!!
I'll turn PM's on now (do you know if they (as in the content) are saved if i turn PM's back off???)
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
10-02-2017 4:01 PM
Sorry for the late reply. I've been having laptop troubles
PM'd you now. Not sure how it works if you turn them off again so would advise to copy the message out first.
10-02-2017 4:11 PM
That's it, blame the laptop!!
Thanks, I'll have look in a mo
I might ask @jaread83 to see if he knows if PM's are wiped/lost/frozen if a user opens one, reads one and then turns PM's off
10-02-2017 5:50 PM
Good spot Mav, my bad. I meant to quote the post above that one!
@scrookes you've got mail, well a PM but it's kinda the same thing
Not sure about the rest of you, but it keeps failing again, therefore either the fix has failed, or the fix for the fix has failed!!
11-02-2017 11:16 AM
Just tried it again today and get the same problems which has been ongoing prior to Christmas last year.
11-02-2017 11:26 AM
Broken here too
11-02-2017 11:57 AM
Further diagnostics broken the day before yesterday, worked yesterday, broken again today.
About par for the course!
11-02-2017 11:57 AM
@DS wrote:
...therefore either the fix has failed, or the fix for the fix has failed!!
Still working for me...
11-02-2017 3:12 PM
